Thanks - that helps.
--- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@...> wrote:
> Not sure if this would work for you, but you could always test it out.
> In part maintenance, under actions, approved suppliers, you can define the mfg part number here with a vantage part number for each supplier.
> Of course then you have to make sure each vendor is approved for that part.
> M. Manasa Reddy
> manasa@... <mailto:manasa@...>
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Keith
> Sent: Wednesday, February 17, 2010 9:32 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Mtg, Mfg PartNum, Part Master PartNum, Supplier PartNum... HELP! 8.03.407
> We currently have several thousand buy items - many of which we can get from multiple suppliers (e.g. electrical components - resistors, capcitors, IC chips). I am defining the "mfg part number" as a number referenced by the actual manufaturer, where the "supplier part number" would be like from a distributor.
> so we have the following relationships (in reality):
> 1) PNvantage-->PNmfg (one to one usualy, but could also be one to many if there is another mfg who makes this)
> 2) PNvantage-->PNsuplier (one to many)
> 3) PNmfg-->PNsuplier (one to many)
> 4) PNsuplier-->Suplier (one to one)
> Make sense?
> OK. Now in Vantage I know how to make #2 and #4 above happen by using the vendor price list. We use it heavily. But how can i get #1 and #3 to work? that is, how can I store and lookup a mfg part number, then see which of my suupliers can provide it? I need to be able to search for MfgPartNumbers related to a VantagePart, and also Vendors who can supply this part to us. On the PO/Line tab, there are feilds for "Mfg" and "Mfg Part". This seems like what I need but HELP is not very helpful, and I cannot find where I would modify this data or where it comes from.
> Can anyone point me in the right direction? Any ideas? How do you handle this?
> Thanks,
> Keith Walter
