MTD & YTD Sales
You should get a consulting fee for this kind of help, Jim. Wow!
Egroups to the rescue!
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, March 16, 2001 3:17 PM
Subject: RE: [Vantage] MTD & YTD Sales
This is how I would attack this report assuming you are on monthly
accounting periods:
1. Include a date range in the filter: InvcDtl.InvoiceDate IN-RANGE
starting date, ending date
2. Create an aggregate for the "maximum value" of "Invcdtl.InvoiceDate",
"no reset", "every composite", "pre-pass" - call it "LastDate". This will
yield the highest actual date found in the filter range. Click the options
button on the aggregate definition window to see the "pre-pass" and "every
composite" parameters.
3. Create a calculated field, "MtdYrMon", --> Year(LastDate) +
(Month(LastDate) / 100) this will yield values like 2001.01 for Jan'01;
2001.02 for Feb'01 ....
4. Create a calculated field, "InvdYrMon" --> Year(InvcDtl.InvoiceDate) +
Month(InvcDtl.InvoiceDate) / 100). Again will yield values like 3 above
(2001.03 )
5. Create a calculated field "InvAmtMTD" --> iif(MtdYrMon = InvdYrMon,
InvcDtl.ExtPrice, 0). This will capture the value of an invoice line when
the Year.month of the invoice matches the Year.month of the last date in
filter range.
Note: you could do steps 3,4,5 as one complex calculation, but I prefer the
less complicated way.
6. Create an Aggregate that totals the MTD sales: Total, InvAmtMTD,
grouping field (Part, Customer... or no reset for grand total), every
composite, final pass.
7. Create an Aggregate that totals the YTD sales: Total, InvcDtl.ExtPrice,
grouping field or no reset, final pass.
Hope this helps
Jim Stetter
Snow Filtration
Sent: Thursday, March 15, 2001 10:19 AM
Subject: [Vantage] MTD & YTD Sales
I am trying to build a report that prints month to date and year to
date sales, on the same report. How do I get around the filter? If
I filter by the year, I can't get MTD sales and vice-versa. Any
ideas?
Yahoo! Groups Sponsor
Click Here to Find Software Faster
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
ideas?
Try creating calculated YEAR fields and calculated MONTH fields. RB has the
formulas to do this. The create a new YEAR group and a month GROUP then
sort by year then by month then by whatever. Add the group footers for the
year and month groups and summarize totals from there.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
accounting periods:
(2001.03 )
filter range.
Hope this helps
Jim Stetter
Snow Filtration
ideas?
