Iβ am having a issue with MRP - it seems to be taking very very long time to run up to 6/8/2019 its been 100% fine since then with no with issue.
I think some in our parts team has been paying with parts but unable to find out that has gone wrong.
Any ideas
Thursday August 8 18:05:31 2019
18:05:31 MRP regeneration process begin.
18:05:31 PID: 7728; Session: 192.0.0.99::Epicor905::9401::9f1c2d3fcc3c911e:319e0680:16c7012020b:-711b
18:05:31 ------------------------------------------------------------
18:05:31 Cut Off Date β 10/31/19
18:05:31 Schedule Start Date β 08/08/19
18:05:31 Run Finite Scheduling β no
18:05:31 Ignore Constrained Materials β no
18:05:31 Allow Historical Dates β yes
18:05:31 Use Production Preparation Buffer β yes
18:05:31 Sort Level 0 MRP Jobs by Date β no
18:05:31 Recycle MRP Jobs β no
18:05:31 Get Details from Quote β no
18:05:31 Run Multi Level Pegging β no
18:05:31 Include Contract PO Parts β no
18:05:31 Generate Purchase Schedules β no
18:05:31 Number of MRP Processes β 3
18:05:31 Number of Schedulers β 3
18:05:31 Rough Cut Schedule When Getting Details β yes
18:05:31 Plant List β MfgSys
18:05:31 Process Control
18:05:31 Name β ProcessorMain; Code β mr/MrpExp.p
18:05:31 Process Stop Queues β Part~Delete~LotJobSplit~SchedJob~FirmJob~SaveLoad
18:05:31 Controller β yes; Range Start β 0; Range End β 0
18:05:31 Name β ProcessorMRP; Code β mr/MrpExpCD.p
18:05:31 Controller β no; Range Start β 1; Range End β 100
18:05:31 Name β ProcessorSched; Code β mr/MrpExpSched.p
18:05:31 Controller β no; Range Start β 101; Range End β 200
18:05:31 Process Queue
18:05:31 Name β BuildDelPOQueue; Queue In β ; Queue Out β DeleteAllPO; Controller β yes
18:05:31 Alt Queue Out 1 β ; Alt Queue Out 2 β ; Alt Queue Out 3 β
18:05:31 Group β Delete; Check Group β ; Repeat β no; Regen Only β yes; Finite β no
18:05:31 Name β BuildDelJob; Queue In β ; Queue Out β DeleteJob; Controller β yes
18:05:31 Name β BuildDelTO; Queue In β ; Queue Out β DeleteTO; Controller β yes
18:05:31 Group β Delete; Check Group β Delete; Repeat β no; Regen Only β yes; Finite β no
18:05:31 Name β ProcessDelPO; Queue In β DeleteAllPO; Queue Out β ; Controller β no
18:05:31 Name β ProcessDelJob; Queue In β DeleteJob; Queue Out β ; Controller β no
18:05:31 Name β ProcessDelTO; Queue In β DeleteTO; Queue Out β ; Controller β no
18:05:31 Name β BuildSched; Queue In β ; Queue Out β PreJobF; Controller β yes
18:05:31 Alt Queue Out 1 β PreJobI; Alt Queue Out 2 β ; Alt Queue Out 3 β
18:05:31 Group β Sched; Check Group β Sched; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β SchedJobF; Queue In β PreJobF; Queue Out β SaveLoad; Controller β no
18:05:31 Group β Sched; Check Group β ; Repeat β no; Regen Only β no; Finite β yes
18:05:31 Name β SchedJobI; Queue In β PreJobI; Queue Out β SaveLoad; Controller β no
18:05:31 Group β Sched; Check Group β ; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β BuildPart0; Queue In β ; Queue Out β Part; Controller β yes
18:05:31 Group β Zero; Check Group β Zero; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β ProcessPart0; Queue In β Part; Queue Out β ZeroJob; Controller β no
18:05:31 Alt Queue Out 1 β LotJobSplit; Alt Queue Out 2 β ; Alt Queue Out 3 β
18:05:31 Group β Zero; Check Group β ; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β LotJobSplitPart0; Queue In β LotJobSplit; Queue Out β ZeroJob; Controller β no
18:05:31 Name β SortPart0; Queue In β ZeroJob; Queue Out β SchedJobF; Controller β yes
18:05:31 Alt Queue Out 1 β SchedJobI; Alt Queue Out 2 β FirmJob; Alt Queue Out 3 β
18:05:31 Group β ZeroSort; Check Group β ZeroSort; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β SchedPart0F; Queue In β SchedJobF; Queue Out β SaveLoad; Controller β no
18:05:31 Alt Queue Out 1 β FirmJob; Alt Queue Out 2 β ; Alt Queue Out 3 β
18:05:31 Group β ZeroSort; Check Group β ; Repeat β no; Regen Only β no; Finite β yes
18:05:31 Name β SchedPart0I; Queue In β SchedJobI; Queue Out β SaveLoad; Controller β no
18:05:31 Group β ZeroSort; Check Group β ; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β FirmJobPart0; Queue In β FirmJob; Queue Out β SaveLoad; Controller β no
18:05:31 Name β BuildPart; Queue In β ; Queue Out β Part; Controller β yes
18:05:31 Group β Part; Check Group β Part; Repeat β yes; Regen Only β no; Finite β no
18:05:31 Name β ProcessPartL; Queue In β Part; Queue Out β SchedJobF; Controller β no
18:05:31 Alt Queue Out 1 β LotJobSplit; Alt Queue Out 2 β SchedJobI; Alt Queue Out 3 β FirmJob
18:05:31 Group β Part; Check Group β ; Repeat β yes; Regen Only β no; Finite β no
18:05:31 Name β LotJobSplitPartL; Queue In β LotJobSplit; Queue Out β SchedJobF; Controller β no
18:05:31 Name β SchedPartLF; Queue In β SchedJobF; Queue Out β SaveLoad; Controller β no
18:05:31 Group β Part; Check Group β ; Repeat β yes; Regen Only β no; Finite β yes
18:05:31 Name β SchedPartLI; Queue In β SchedJobI; Queue Out β SaveLoad; Controller β no
18:05:31 Name β FirmJobPartL; Queue In β FirmJob; Queue Out β SaveLoad; Controller β no
18:05:31 Name β BuildNonPart; Queue In β ; Queue Out β Part; Controller β yes
18:05:31 Group β NonPart; Check Group β NonPart; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β ProcessNonPart; Queue In β Part; Queue Out β SchedJobF; Controller β no
18:05:31 Group β NonPart; Check Group β ; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β LotJobSplitNonPart; Queue In β LotJobSplit; Queue Out β SchedJobF; Controller β no
18:05:31 Name β SchedNonPartF; Queue In β SchedJobF; Queue Out β SaveLoad; Controller β no
18:05:31 Group β NonPart; Check Group β ; Repeat β no; Regen Only β no; Finite β yes
18:05:31 Name β SchedNonPartI; Queue In β SchedJobI; Queue Out β SaveLoad; Controller β no
18:05:31 Name β FirmJobNonPart; Queue In β FirmJob; Queue Out β SaveLoad; Controller β no
18:05:31 Name β ProcessLoad; Queue In β ; Queue Out β ; Controller β yes
18:05:31 Group β Load; Check Group β Load; Repeat β no; Regen Only β no; Finite β no
18:05:31 Name β SaveLoad; Queue In β SaveLoad; Queue Out β ; Controller β no
18:05:31 Group β Load; Check Group β ; Repeat β no; Regen Only β no; Finite β no
18:05:31 Starting sub-processes
18:05:32 Deleting old Suggestions.
18:05:32 Deleting unfirm jobsβ¦
18:05:32 Deleting transfer order suggestions β¦
18:05:42 Scheduling Jobsβ¦
18:05:43 Building PartList Level: 0
18:12:31 Building PartList Level: 1
18:13:20 Building PartList Level: 2
18:14:02 Building PartList Level: 3
18:14:32 Building PartList Level: 4
18:14:50 Building PartList Level: 5
19:15:11 Process 2 not responding. Abandoned during process βProcessing Part~FORGING BILLETβ
19:15:11 Building PartList Level: 6
20:15:33 Process 2 not responding. Abandoned during process βProcessing Part~C2610-Profileβ
20:15:33 Building PartList Level: 7
20:15:39 Building PartList Level: 8
20:15:50 Building Non-Part List
20:16:01 Processing Schedule Load
20:17:21 disconnect Process 002
20:17:21 disconnect Process 001
20:17:21 disconnect Process 003
20:17:21 disconnect Process 101
20:17:21 disconnect Process 102
20:17:21 disconnect Process 103
20:17:31 Processing Orphan POβsβ¦
20:17:36 MRP regeneration process finished.!
could this be an with the C2610-Profile part?
