MRP Still running in background after killing Task
10.2.500.19 - We needed to kill Net Change MRP due to someone requesting over 800,000 of a part.
We killed the task agent and removed the Task Agent Kill but the log files are still showing activity.
Anyone have this issue before? We need to stop the process, task agent has been restarted and still running.
Chris Wineinger
Dorner Mfg
Stopped the application pool and solved it
@RedRhyno13 - Here ya go:
Yep did that but it’s still running in the background. Epicor says once it’s off the active task agent, the only way to stop it is a restart.
The sql method works 95% of the time
The only way to stop this is to bounce the application Pool.
