Good Day Lauren:
Sun went live on 11/29/10
on Epicor 9, 9.05.601B SQL-Unidata
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
Our MRP takes about 2.5 hours with REGEN - about 12 minutes
Net-Change - 289,000 Part#'s - 40,000 with usage.
To have regen and Net-Change take the same time is very odd.
Very important that you run it with "Number of MRP Process" = 6 ( if
you have two-Quad processors), also set " number of Schedulers" to the
same number.
Example: Full regen 2 processors = 15 hours, 6 processor =
2.5
MRP does do a tremendous amount of things:
1. It deletes all Suggestions and Unfirmed-Planned-Jobs in Regen
Mode ( does not do that in Net-Change)
2. It then goes through all parts by level. and taking ALL the
various MRP settings into account - Min-Max, Safety-Stock, Qty-Bearing,
MRP-Fence, Days-Supply, etc.
Then it explodes the components of any Manufactured Parts.
3. Using all that it creates new PO-Suggestions, and
Unfirmed-Planned-orders ( many of the lines deleted in first step are
now re-created) , it also makes suggestions for Changes to PO-Qty's and
Due-Dates.
len.hartka@...
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com
Of Hellings, Lauren
Sent: Tuesday, March 29, 2011 8:32 AM
Subject: [Vantage] MRP Runtime
We are running Epicor 9.05.603 and we are seeing excessively long
processing times on MRP. Doesn't matter if we run a full regen or a net
change, the process always takes almost 20 hours. What kind of times is
everyone out there seeing? Does anyone know specifically what is
happening in the background when MRP is processing? We have posed this
question to several Epicor resources, but no one can seem to answer
these questions.
Any help would be greatly appreciated.
Thank you,
Lauren Hellings
Business Analyst
Office: 281-207-0667 x26
Cell: 832-472-1736
Fax: 281-207-0672
email: lauren.hellings@... <mailto:lauren.hellings%40c-p-i.com>
<mailto:lauren.hellings@... <mailto:lauren.hellings%40c-p-i.com> >
www.c-p-i.com<http://www.c-p-i.com/>
----------Legal Disclaimer----------
The information contained in this message may be privileged and
confidential, and is intended solely for the use of the named addressee.
No other person is authorized to access, copy or re-use this message (or
any information contained herein). If you are not the intended
recipient, please notify us immediately by replying to this message and
delete it from your computer.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
same number.
2.5
Due-Dates.
len.hartka@...
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
len.hartka@...
Of Hellings, Lauren
these questions.
Thank you,
Lauren Hellings
Business Analyst
Cell: 832-472-1736
Fax: 281-207-0672
