The questions is why do you want to remove them? Are they not correct and if so have you looked at why they are not giving you correct information (i.e. Moms not setup correctly?)
Â
If you do not want PO suggestions to show up for parts then you can uncheck generate PO suggestions on the part master
Â
--- On Fri, 9/18/09, NancyM <vantageuser13@...> wrote:
Subject: [Vantage] MRP Purchase Suggestion
Date: Friday, September 18, 2009, 7:55 AM
Â
My problem is: I need to remove my screen MRP PO New Suggestion. Is there a way to remove them?
Thank you!
Vantage 8.03.305
