Type:3Program:mr/cpmethod.pMethod:Main-BlockTable:JobAsmblField:Rowid:Message:The requested Job Assembly was not found.
Anyone know what this error message means? Attached is the log fine.
MRP_WLB_RegenWed006.TXT (4.6 MB)
I know this has something to do with Pull or View as assembly but I don’t know for sure and where to direct the users to correct the error. Any help would be appreciated.
Dear Kimberley,
We frequently see a member of our engineering staff forget to check in a component assembly after opening in Engineering Workbench, and as a result our MRP run that night will refuse to process any demand for the item, because it has no approved rev. In line 527 of your file, please see this message:
20:38:54 Type:3Program:mr/cpmethod.pMethod:Main-BlockTable:Field:Rowid:Message:Source Part Revision not found. Part/Rev:10916-256/
This indicates there is no approved revision for P/N 10916-256 for the date it’s trying to schedule the job. Could you check?
Best,
…Monty.
Monty, i got that one resolved but this one is different. I don’t have a Part Rev failed on a new one. And some of the jobs create fine then one gets this error then the next one is fine.
23:51:08 Creating new unfirm job:032693-1-1 Quantity:1.
23:51:09 Adding to job:032693-1-1 Quantity:1.
23:51:09 Copying BOM from Part:14T234T004-1 Rev:A/- to Job:032693-1-1.
23:51:09 Sent job 032693-1-1 to SchedJobI
23:51:10 Processing order requirement, Order:33012 Line:1 Rel:1.
23:51:10 Get Destination
23:51:10 Create Interplant Supply
23:51:10 Type:3Program:mr/cpmethod.pMethod:Main-BlockTable:JobAsmblField:Rowid:Message:The requested Job Assembly was not found.
23:51:10 Error copying BOM, deleting Job:033012-1-1.
23:51:10 Deleting unfirm job 033012-1-1
23:51:10 Processing order requirement, Order:33013 Line:1 Rel:1.
23:51:10 Creating new unfirm job:033013-1-1 Quantity:1.
23:51:10 Adding to job:033013-1-1 Quantity:1.
23:51:10 Copying BOM from Part:14T234T004-1 Rev:A/- to Job:033013-1-1.
23:51:11 Sent job 033013-1-1 to SchedJobI
