MRP Log Blank Title 124320
DoSuggestions:
The DoSuggestions basically means that it is refreshing/recalculating the suggestions to see if it needs to make any other change suggestions based on changes to the part's demand.
Anyything different in the jobs from 9/23 and 10/16
Max size is 1, so you should always get a 1 to 1 and shouldnt ask you to change Qty on jobs.
Can you create another demand job the same time and see if it processes that job.  Maybe some bad data for the 10/16 job.
Maybe the Part Onhand and TimePhase are out of Sync.  Conversion 6430?
I say that because in the MRP log is starts with balance of 0, but then it states there is a balance of 1.  NOt sure if that is because there is a Job for 1 on 9/23
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Marco Vissuet
Sent: Friday, September 06, 2013 8:23 AM
Subject: [Vantage] RE: MRP Log
Yeah… that’s my question… why wouldn’t MRP create the jobs for 10/16
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Cell (619)507-2311
Anaheim Office (714) 693-1260
San Diego Office (619)670-3900
Fax (714) 693-1252
mvissuet@...
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties.  Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Serwe
Sent: Friday, September 06, 2013 6:41 AM
Subject: RE: [Vantage] MRP Log
It looks like MRP is creating jobs for other demand but it is still missing
the job due on 10/16
Josh Serwe
Wisconsin Converting Inc.
Warehouse & Logistics Manager
(920)437-6400 x 330
Marco Vissuet
Sent: Thursday, September 05, 2013 6:09 PM
We are on 9.05.606
Min On Hand (0)
Max On Hand (0)
Safety Stock (0)
Part Type Manufactured
Days of Supply (0)
Min Lot Size (0)
Max Lot Size (1)
Lot Multiple (0)
This is what time phase looks like:
Not: I had to manually create job number A18825 because MRP did not create
it.
Due
Receipts
Required Qty
Balance
UOM
Source
Exception
Order By
Lead
JobStatus
Job
0
0
0
EA
On-hand Quantity
0
9/23/2013
1
0
1
EA
Job: A18825
0
Released
A18825
9/23/2013
0
1
0
EA
Job: AMRP0000012496 (0/20)
0
Engineered
AMRP0000012496
10/16/2013
0
1
-1
EA
Job: AMRP0000012497 (0/20)
Below Zero
1/10/2013 0:00
199
Engineered
AMRP0000012497
12/16/2013
1
0
0
EA
Job: AMRP0000015174
0
Engineered
AMRP0000015174
12/16/2013
0
1
-1
EA
Job: AMRP0000012498 (0/20)
Below Zero
3/12/2013 0:00
199
Engineered
AMRP0000012498
1/2/2014
1
0
0
EA
Job: AMRP0000015175
0
Engineered
AMRP0000015175
1/2/2014
0
1
-1
EA
Job: AMRP0000012499 (0/20)
Below Zero
3/29/2013 0:00
199
Engineered
AMRP0000012499
1/14/2014
1
0
0
EA
Job: AMRP0000015176
0
Engineered
AMRP0000015176
1/14/2014
0
1
-1
EA
Job: AMRP0000012500 (0/20)
Below Zero
4/10/2013 0:00
199
Engineered
AMRP0000012500
2/5/2014
1
0
0
EA
Job: AMRP0000015177
0
Engineered
AMRP0000015177
2/5/2014
0
1
-1
EA
Job: AMRP0000012501 (0/20)
Below Zero
5/2/2013 0:00
199
Engineered
AMRP0000012501
5/15/2014
1
0
0
EA
Job: AMRP0000015178
0
Engineered
AMRP0000015178
5/15/2014
0
1
-1
EA
Job: AMRP0000012502 (0/20)
Below Zero
8/9/2013 0:00
199
Engineered
AMRP0000012502
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Miguel Santillan
Sent: Thursday, September 05, 2013 2:14 PM
really tough without seeing the parameters for the plant and what timephase
is showing.
I do know that Safety Stock is checked and you dont have a balance it will
use the LT when creating a job.
Curious what it means...what version are you on?
mvissuet@...
Sent: Thursday, September 05, 2013 11:14 AM
Subject: [Vantage] MRP Log
Can someone explain to me why MRP did not create a job for a part for a
certain need date, but it does create it for a different date... instead it
did a doSuggestion what is that?
the effective date on the revision is 1/1/2000
here is the log:
23:00:15 Processing Part:791S-STA95FRAME_01. V200
23:00:15 Processing Part:791S-STA95FRAME_01 Plant:PCAD.
23:00:15 Parameters: Receive Time -> 0; Planning Fence -> 0; Delta In -> 0;
Delta Out -> 0; Lead Time CutOff -> ?, Use Dynamic DOS -> no, Allow Consume
Min -> no
23:00:15 Deleting suggestions
23:00:15 Processing non-stock transactions for Part:791S-STA95FRAME_01.
23:00:15 Processing stock transactions for Part:791S-STA95FRAME_01.
23:00:15 Beginning Balance 0
23:00:15 Date changed, process date ?
23:00:15 Date changed, process date 09/23/13
23:00:15 over re-order, DoSuggestion...
23:00:15 After DoSuggestions, balance is:1.
23:00:15 Date changed, pro cess date 10/16/13
23:00:15 Date changed, process date 12/16/13
23:00:15 Below re-order, expedite jobs.
23:00:15 Expedite-jobs - qty needs to be expedited:1
23:00:15 Expedite-jobs - Total requirement: 1
23:00:15 Total quantity expedited:0.
23:00:15 Get Destination
23:00:15 Create Interplant Supply
23:00:15 Creating new unfirm job:AMRP0000015174 Quantity:1.
23:00:15 Adding to job:AMRP0000015174 Quantity:1.
23:00:15 Copying BOM from Part:791S-STA95FRAME_01 Rev:A1/1/1 to
Job:AMRP0000015174.
23:00:20 Sent job AMRP0000015174 to SchedJobI
23:00:20 Date changed, process date 01/02/14
23:00:20 Below re-order, expedite jobs.
23:00:20 Expedite-jobs - qty needs to be expedited:1
23:00:20 Expedite-jobs - Total requirement: 1
23:00:20 Total quantity expedited:0.
23:00:20 Get Destination
23:00:20 Create Interplant Supply
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 8768 (20130905) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 8770 (20130906) __________
http://www.eset.com
Can someone explain to me why MRP did not create a job for a part for a certain need date, but it does create it for a different date... instead it did a doSuggestion what is that?
here is the log:
23:00:15 Parameters: Receive Time -> 0; Planning Fence -> 0; Delta In -> 0; Delta Out -> 0; Lead Time CutOff -> ?, Use Dynamic DOS -> no, Allow Consume Min -> no
23:00:15 Date changed, process date 10/16/13
23:00:15 Copying BOM from Part:791S-STA95FRAME_01 Rev:A1/1/1 to Job:AMRP0000015174.
really tough without seeing the parameters for the plant and what timephase is showing.
I do know that Safety Stock is checked and you dont have a balance it will use the LT when creating a job.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mvissuet@...
here is the log:
We are on 9.05.606
Min On Hand  (0)
Max On Hand (0)
Safety Stock (0)
Days of Supply (0)
Min Lot Size (0)
Max Lot Size (1)
Lot Multiple (0)
Not:  I had to manually create job number A18825 because MRP did not create it.
Due
Receipts
Required Qty
Balance
UOM
Source
Exception
Order By
Lead
JobStatus
Job
0
0
0
EA
On-hand Quantity
0
9/23/2013
1
0
1
EA
Job: A18825
0
Released
A18825
9/23/2013
0
1
0
EA
0
Engineered
AMRP0000012496
10/16/2013
0
1
-1
EA
Below Zero
1/10/2013 0:00
199
Engineered
AMRP0000012497
12/16/2013
1
0
0
EA
Job: AMRP0000015174
0
Engineered
AMRP0000015174
12/16/2013
0
1
-1
EA
Below Zero
3/12/2013 0:00
199
Engineered
AMRP0000012498
1/2/2014
1
0
0
EA
Job: AMRP0000015175
0
Engineered
AMRP0000015175
1/2/2014
0
1
-1
EA
Below Zero
3/29/2013 0:00
199
Engineered
AMRP0000012499
1/14/2014
1
0
0
EA
Job: AMRP0000015176
0
Engineered
AMRP0000015176
1/14/2014
0
1
-1
EA
Below Zero
4/10/2013 0:00
199
Engineered
AMRP0000012500
2/5/2014
1
0
0
EA
Job: AMRP0000015177
0
Engineered
AMRP0000015177
2/5/2014
0
1
-1
EA
Below Zero
5/2/2013 0:00
199
Engineered
AMRP0000012501
5/15/2014
1
0
0
EA
Job: AMRP0000015178
Josh Serwe
(920)437-6400 x 330
Marco Vissuet
We are on 9.05.606
Min On Hand (0)
Max On Hand (0)
Safety Stock (0)
Days of Supply (0)
Min Lot Size (0)
Max Lot Size (1)
Lot Multiple (0)
it.
Due
Receipts
Required Qty
Balance
UOM
Source
Exception
Order By
Lead
JobStatus
Job
0
0
0
EA
On-hand Quantity
0
9/23/2013
1
0
1
EA
Job: A18825
0
Released
A18825
9/23/2013
0
1
0
EA
0
Engineered
AMRP0000012496
10/16/2013
0
1
-1
EA
Below Zero
1/10/2013 0:00
199
Engineered
AMRP0000012497
12/16/2013
1
0
0
EA
Job: AMRP0000015174
0
Engineered
AMRP0000015174
12/16/2013
0
1
-1
EA
Below Zero
3/12/2013 0:00
199
Engineered
AMRP0000012498
1/2/2014
1
0
0
EA
Job: AMRP0000015175
0
Engineered
AMRP0000015175
1/2/2014
0
1
-1
EA
Below Zero
3/29/2013 0:00
199
Engineered
AMRP0000012499
1/14/2014
1
0
0
EA
Job: AMRP0000015176
0
Engineered
AMRP0000015176
1/14/2014
0
1
-1
EA
Below Zero
4/10/2013 0:00
199
Engineered
AMRP0000012500
2/5/2014
1
0
0
EA
Job: AMRP0000015177
0
Engineered
AMRP0000015177
2/5/2014
0
1
-1
EA
Below Zero
5/2/2013 0:00
199
Engineered
AMRP0000012501
5/15/2014
1
0
0
EA
Job: AMRP0000015178
0
Engineered
AMRP0000015178
5/15/2014
0
1
-1
EA
Below Zero
8/9/2013 0:00
199
Engineered
AMRP0000012502
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Miguel Santillan
is showing.
mvissuet@...
here is the log:
Min -> no
Job:AMRP0000015174.
http://www.eset.com
http://www.eset.com
Would a Planning Time Fence lead to this behavior?
Sent: Friday, September 06, 2013 9:41 AM
Josh Serwe
(920)437-6400 x 330
Marco Vissuet
We are on 9.05.606
Min On Hand (0)
Max On Hand (0)
Safety Stock (0)
Days of Supply (0)
Min Lot Size (0)
Max Lot Size (1)
Lot Multiple (0)
it.
Due
Receipts
Required Qty
Balance
UOM
Source
Exception
Order By
Lead
JobStatus
Job
0
0
0
EA
On-hand Quantity
0
9/23/2013
1
0
1
EA
Job: A18825
0
Released
A18825
9/23/2013
0
1
0
EA
0
Engineered
AMRP0000012496
10/16/2013
0
1
-1
EA
Below Zero
1/10/2013 0:00
199
Engineered
AMRP0000012497
12/16/2013
1
0
0
EA
Job: AMRP0000015174
0
Engineered
AMRP0000015174
12/16/2013
0
1
-1
EA
Below Zero
3/12/2013 0:00
199
Engineered
AMRP0000012498
1/2/2014
1
0
0
EA
Job: AMRP0000015175
0
Engineered
AMRP0000015175
1/2/2014
0
1
-1
EA
Below Zero
3/29/2013 0:00
199
Engineered
AMRP0000012499
1/14/2014
1
0
0
EA
Job: AMRP0000015176
0
Engineered
AMRP0000015176
1/14/2014
0
1
-1
EA
Below Zero
4/10/2013 0:00
199
Engineered
AMRP0000012500
2/5/2014
1
0
0
EA
Job: AMRP0000015177
0
Engineered
AMRP0000015177
2/5/2014
0
1
-1
EA
Below Zero
5/2/2013 0:00
199
Engineered
AMRP0000012501
5/15/2014
1
0
0
EA
Job: AMRP0000015178
0
Engineered
AMRP0000015178
5/15/2014
0
1
-1
EA
Below Zero
8/9/2013 0:00
199
Engineered
AMRP0000012502
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Miguel Santillan
is showing.
mvissuet@...
here is the log:
Min -> no
Job:AMRP0000015174.
http://www.eset.com
http://www.eset.com
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Josh Serwe
(920)437-6400 x 330
Marco Vissuet
We are on 9.05.606
Min On Hand (0)
Max On Hand (0)
Safety Stock (0)
Days of Supply (0)
Min Lot Size (0)
Max Lot Size (1)
Lot Multiple (0)
it.
Due
Receipts
Required Qty
Balance
UOM
Source
Exception
Order By
Lead
JobStatus
Job
0
0
0
EA
On-hand Quantity
0
9/23/2013
1
0
1
EA
Job: A18825
0
Released
A18825
9/23/2013
0
1
0
EA
0
Engineered
AMRP0000012496
10/16/2013
0
1
-1
EA
Below Zero
1/10/2013 0:00
199
Engineered
AMRP0000012497
12/16/2013
1
0
0
EA
Job: AMRP0000015174
0
Engineered
AMRP0000015174
12/16/2013
0
1
-1
EA
Below Zero
3/12/2013 0:00
199
Engineered
AMRP0000012498
1/2/2014
1
0
0
EA
Job: AMRP0000015175
0
Engineered
AMRP0000015175
1/2/2014
0
1
-1
EA
Below Zero
3/29/2013 0:00
199
Engineered
AMRP0000012499
1/14/2014
1
0
0
EA
Job: AMRP0000015176
0
Engineered
AMRP0000015176
1/14/2014
0
1
-1
EA
Below Zero
4/10/2013 0:00
199
Engineered
AMRP0000012500
2/5/2014
1
0
0
EA
Job: AMRP0000015177
0
Engineered
AMRP0000015177
2/5/2014
0
1
-1
EA
Below Zero
5/2/2013 0:00
199
Engineered
AMRP0000012501
5/15/2014
1
0
0
EA
Job: AMRP0000015178
0
Engineered
AMRP0000015178
5/15/2014
0
1
-1
EA
Below Zero
8/9/2013 0:00
199
Engineered
AMRP0000012502
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Miguel Santillan
is showing.
mvissuet@...
here is the log:
Min -> no
Job:AMRP0000015174.
http://www.eset.com
http://www.eset.com
http://www.eset.com
