I am getting this message when i try to process MRP. Please advise.
“EpicorLive”: A communication error occurred trying to run task ID 239275 for agent “DefaultSystemAgent” on the application server (User: “manager”, Task Description: “Process MRP”).
If this continues to happen investigate if you need to increase the receive and send timeouts in your web.config.
Error details:
System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘1.00:00:00’. —> System.IO.IOException: The read operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘1.00:00:00’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
