Blockquote
11:43:00 Done Scheduling job:MRP00000000033 sending job to queue SaveLoad
11:46:33 System.FormatException: String was not recognized as a valid Boolean.
at System.Boolean.Parse(String value)
at Erp.Internal.MR.MRPLib.GetJobQueue(Int64 pTaskNum, String pName, String pProcessor, Int32 pNum, String pMsg, String& pJobNum, String& pPlant, String& pPartNum, String& pType, Int32& pPriFactor, Nullable1& pReqDate, Int32& pReqTime, Int32& pLevel, Boolean& pMethod, Decimal& pSeq, Boolean& pSchedDir, Boolean& pFirm, Boolean& pReNum, Boolean& pSched, String& pStatus, Int32& pSubLLC) in C:\_Releases\ERP\RL10.2.500.0\Source\Server\Internal\MR\MRPLib\MRPLib.cs:line 1834 at Erp.Internal.MR.MrpExpSched.main_block(Int64 instance_TaskNum, Boolean netchg, String IP_plantList, Nullable
1 cutoff_date, Boolean from_autopur, String logfile, Int32 loglevel, Int32 logtype, Boolean finiteLoad, Boolean ignoreConst, Boolean allowHistDate, Boolean usePrepTime, Boolean useKitTime, Boolean runPegging, Boolean runConPur, Nullable1 Sched_startDate, String ShipViaDefault, String compBuyerID, Int32 ForeDaysB, Int32 ForeDaysA, String v_defaultSchedCode, String extComp, String PlantSelected, String plantprefixlist, String pReqType, Int32 processNum, String purDir, Boolean whatif, String procSource, Decimal GSStartTime, Boolean delaySched, Boolean recyclejobs, Boolean rcSchedGetDetails, Boolean includePCParts, Boolean useQuoteBOM, Boolean multiJob, Boolean multiJobIgnoreLocks, Boolean multiJobMinimizeWIP) in C:\_Releases\ERP\UD10.2.500.27\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 3443 at Erp.Internal.MR.MrpExpSched.RunMrpExpSched(Int64 instance_TaskNum, Boolean netchg, String IP_plantList, Nullable
1 cutoff_date, Boolean from_autopur, String logfile, Int32 loglevel, Int32 logtype, Boolean finiteLoad, Boolean ignoreConst, Boolean allowHistDate, Boolean usePrepTime, Boolean useKitTime, Boolean runPegging, Boolean runConPur, Nullable1 Sched_startDate, String ShipViaDefault, String compBuyerID, Int32 ForeDaysB, Int32 ForeDaysA, String v_defaultSchedCode, String extComp, String PlantSelected, String plantprefixlist, String pReqType, Int32 processNum, String purDir, Boolean whatif, String procSource, Decimal GSStartTime, Boolean delaySched, Boolean recyclejobs, Boolean rcSchedGetDetails, Boolean includePCParts, Boolean useQuoteBOM, Boolean multiJob, Boolean multiJobIgnoreLocks, Boolean multiJobMinimizeWIP) in C:\_Releases\ERP\UD10.2.500.27\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 1069 at Erp.Internal.MR.MrpExpSched.RunSubProcess(List
1 Parameters) in C:_Releases\ERP\UD10.2.500.27\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 746
