Just some possible places to start looking: Did you make any changes to the resource groups attached to the operations recently? When you add the operation back on, does a different resource group show up and is the original resource group assigned to a zero-time calendar?
--- In vantage@yahoogroups.com, "supertico05" <mvissuet@...> wrote:
> In Epicor 9.05
> we are beginning to have errors when MRP runs. The funny part of it, is that it's not consistent... a part will run fine for weeks then all of the sudden I get this error.
> 20:46:52 Creating new unfirm job:SMRP0000003960 Quantity:11.
> 20:46:52 Adding to job:SMRP0000003960 Quantity:11.
> 20:46:52 Copying BOM from Part:954036C3 Rev:#S1/R to Job:SMRP0000003960.
> 20:46:53 Type:3Program:es/roughcutdate.pMethod:getDateHourTable:JobOperField:Rowid:Message:Working calendar for scheduling not found.
> 20:46:53 Error copying BOM, deleting Job:SMRP0000003960.
> 20:46:53 Creating new mfg suggestion for Part:954036C3 Quantity:11 on 12/30/12.
> I fit it by checking out the part, deleting the operations and adding them again. then MRP works just fine. but the next time it runs it has the exact same problem on a different part... even if that part has had approved methods since last year, and there has always been demand for the part.
> Anyone know what might be causing this?
