> > The use part rev check box is not checked on any of our parts.Sorry I missread this in your original post
> > Demand is in Plant AHow was the demand created?
> > Job is created in Plant A
> > Revision used on the job is for Plant B
Transfer order to Plant A
In part plant the part is set up as a transfer part for plant A and as a manufactured part in Plant B
All the demand in Plant A is from MRP jobs, all unfirm.
>> From Online Help for Use Part Rev[Non-text portions of this message have been removed]
>> If you clear this check box, you can manually create
>> demand in MRP for different revisions of the same part,
>> and the Epicor application honors the different revisions.
