MRP Crash - (CLOSED-RESOLVED)
Brian,
The problem was that our MRP regeneration runs would either crash or hang.
I don't know what the nullfixer routine does as nobody really explained it
but it apparently worked because we have run MRP successfully several
times now.
Dale.
Dale Walker
Director, Information Technology
Le Sueur Incorporated
507-665-6204 ext 277
www.lesueurinc.com
We are in the middle of a 3-day simulation and are in the ditch.
We are newbees and Epicor support has failed us once again.
We ran MRP late yesterday afternoon an it crashed with some archaic
error message. I called support first thing this morning, waited over
an hour and didn't hear back. I then called with a system down
condition since our simulation exercise cannot proceed without MRP
being completed. They wanted me to send log files and gave me the
folder and file names to send (which were the wrong ones by the
way...)
Anyway...we were told to re-run it again. We restarted it and it is
hung up. We updated the call asking for an expedited response and
have heard nothing. It is now 1:00 and we are still dead in the
water.
Can anyone here help?
We can see the "next part number" to process in the system monitor
and it is not changing.
What should we look for?
thx,
Dale.
What version are you on and are you a SQL customer?
Of dswmaom
Sent: Tuesday, December 09, 2008 1:51 PM
Subject: [Vantage] MRP Crash
way...)
water.
thx,
Dale.
8.03.406
SQL
Dale Walker
www.lesueurinc.com
"Vic Drecchio" <Vic.Drecchio@...>
12/09/2008 12:51 PM
To
<vantage@yahoogroups.com>
cc
<dwalker@...>
Subject
RE: [Vantage] MRP Crash
Of dswmaom
way...)
water.
thx,
Dale.
You may be experiencing record locking.
We are also a SQL customer and recently had similar issues.
Make sure you run MRP with only one process.
Also, if you haven't already, I *highly* recommend you run through
Epicor's SQL Tuning support doc (pasted below). It resolved all of our
record locking issues. Knock on wood, MRP has never frozen since.
Below is the document Epicor sent to me.
Also, run the SQL script attached. It changes some indexes to
non-clustered.
I went through each step below and now we're set.
Good luck.
Summary: PERF Performance Tuning for an SQL DB
Book: Support Solutions
Page: 8723MPS
XA803
FURTHER INFORMATION: An SQL database does not use most of the Progress
settings, so the performance tuning that can be done is limited.
This document is for an SQL databases only.
Remember that Epicor recommends having one server for Vantage alone.
RECOMMENDATIONS:
A. The mfgsys.pf file. This file is the parameter file for the Vantage
database. For an SQL database, it controls the client connection to the
database. The first line of that file should have the following
settings:
OE 10.0B:
-Mm 1024 -mmax 65534 -Bt 1024 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok
4000 -TB 31 -TM 32 -D 500 -l 1000
OE 10.1B:
4000 -TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5
If any are missing, they can be added in. Changes will not take effect
until the AppServers and database are stopped and started in the
Progress Explorer Tool.
B. There may be a problem with AppServers trimming when they are no
longer needed. Any unused AppServers will hang, and not be available
for future processes that need them. This problem has been addressed in
the most recent Open Edge service packs: OE 10.1B0307 (and higher) or
OE 10.0B0546 (and higher).
If these service packs cannot be applied immediately, configure the
AppServer to not trim any unused AppServers. That will prevent any from
hanging and leave them available for future processes, but will use more
server resources with them open. Use the following procedure to set
this up:
1. Go the Vantage/Vista server.
2. Go to Start->Programs->Open Edge 10.1B->Progress Explorer Tool.
3. Expand the AppServer folder to MfgSys803.
4. Right-click on MfgSys803 and choose Properties.
5. Expand Agent and highlight Pool Range.
6. Change the Initial, Minimum, and Maximum to the same value. Some
experimentation may be necessary to get the correct value.
7. Click OK to save the changes.
8. These changes will not take effect until the AppServers are stopped
and restarted in the Progress Explorer Tool. Stop the AppServers, then
start the AppServers in the Progress Explorer Tool.
NOTE: This step will address performance problems caused by failure to
trim servers. But the increased number of AppServers will use more RAM
on the server. Things may run slower, but there will be less failures
to connect. Open Edge 10.1B03 hot fix 7 and higher (or OE 10.1B05
hotfix 46 or higher) address this problem. After this Open Edge patch
is installed, these Pool Range settings should be set back to their
original values.
C. Some setting for the schema holder in the Progress Explorer Tool can
be adjusted. These settings will vary depending on server resources,
database size, and the number of users. These changes will not take
effect until the DB is stopped and restarted in the Progress Explorer
Tool. Stop the AppServers, then stop the database. Start database,
then start the AppServers for this database in the Progress Explorer
Tool. NOTE: This step will not have any effect if step D (below) is
implemented.
1. # Blocks in DB Buffer. The number of data blocks that will
be loaded into memory when the database is started. With an SQL
database, this value is not used, so it can be set very low. Steps for
changing the #Blocks in DB Buffer:
A. Go the Vantage/Vista server.
B. Go to Start->Programs->Open Edge 10.1B->Progress Explorer Tool.
C. Expand the Database folder to MfgSys803, to Configurations, to
DefaultConfiguration.
D. Right-click on DefaultConfiguration and choose Properties.
E. Change the # Blocks in DB Buffer to 10000. That is all that is
needed for the Progress schema holder.
F. Click OK to save the changes.
2. # Lock Table Entries. The number of record locks made to
the data at any given time. This number can be quite large when running
processes like MRP. Some performance problems result from too many
records being accessed at a given time. The error "Lock table overflow,
increase -L on server (915)" may occur in this case. This can be
addressed by increasing the # Lock Table Entries in the Progress
Explorer Tool:
E. Increase the # Lock Table Entries.
F. Increase that number to 409600 or higher. A multiple of 8192 is
recommended by Progress.
G. Click OK to save the changes.
3. Spin Locks. The number of times a process tries to acquire
a latch before pausing. If the process cannot acquire the resource's
latch, it continues the attempt. This iterative process is called
spinning. Use the following steps to adjust the Spin Locks:
E. Go to the Advanced section.
F. Increase Spin Locks Retries. Progress recommends 20000 per
processor. So, dual/dual core CPU should be set to 80000.
4. Background Writers. For an SQL database, these processes
are not used in the Progress Explorer Tool. Shutting them down will
free up some of the server's resources:
E. Go to the Background Writers section.
F. Set the # APW's to start to 0.
G. Uncheck the Auto startup check boxes for the Before-image writer and
After-image writer.
H. Click OK to save the changes.
D. The schema holders for the database can be set to read-only. This
may help with client performance. This should not be done if there are
third party products connecting to the Vantage DB. See document 8782MPS
for details. If there are third party products, contact Support.
E There is an SQL indexing script that can be run. The script changes
the Progress_recid index of tables to be non-clustered. This will help
improve performance, in cases of locking, poor performance, or MRP
issues. See document 8927MPS for details. If there are any questions
about this document, contact Support.
F. AppServers can be set to see which client PC is causing a problem.
This requires replacing one file on the server. AppServers will then
track the client PC name. See document 8973MPS (for V8.03.305) or
8974MPS (for V8.03.403) for details.
G. Permissions on the Vantage server. Epicor recommends both the
\Epicor folder and the \Mfgsysdata folders be shared full control, for
everyone.
H. Hardware. Microsoft SQL is self-tuning by default. If more
hardware resources are added to the Vantage server, SQL will
automatically tune itself for the new hardware.
I. Documents and Settings (DNS) Version Tracking. Customers
experiencing workstation problems (lockups and display issues) should do
the following:
1. At the workstation, get out of Vantage.
2. Right mouse click the Windows [Start] button, select Explorer.
3. Go to C:\Documents and Settings\All Users\Application
Data\Epicor\Vantage or Vista
4. Delete ALL of the Versional folders below the Vista or Vantage
folder.
5. Log back into Vista\Vantage.
J. Hyperthreading should not be enabled if SQL is installed. In most
cases, SQL2005 will not install. See page 7663MPS for how to turn off
Hyperthreading.
K. Business Activity Query and SQL Issues
SQL function syntax is stricter than Progress syntax. If you previously
ran the application using a Progress
database but now have moved to SQL, you may experience these syntax
issues.
The main issue is that you can use abbreviations within Progress; for
example, ABSOLUTE can be abbreviated to ABS, ABSO, or ABSOL within
Progress. BAQ formulas are directly sent to SQL. As long as these
formulas do not contain any abbreviations, they work as expected.
However if a formula references an abbreviation, syntax issues occur.
The following table displays the functions which are not identical
between Progress and SQL. The characters contained between the
parentheses are optional characters in Progress.
Progress SQL (Before Translation)
SQL (After Translation)
ABS(OLUTE) ABS
abs
ASC(II) ASC
ascii
INT(EGER) INTEGER
convert
MAX(IMUM) MAXIMUM
dbo.maximum (user-defined function)
MIN(IMUM) MINIMUM
dbo.minimum (user-defined function)
L. Check External Company Maintenance. If there are External Companies
setup that are not being used, those may cause a problem. If an
External Company is not being used, it should be deleted. NOTE: It is
*vitally* important that External Companies being used are *not*
deleted.
M. Full Text Cataloging Set to Track Changes. In SQL Server 2005, if
the tracking option is set to automatic, it can cause performance issues
such as locking and speed degradation. This is a known Microsoft issue
and will be addressed in SQL Server 2008. See page 9494MPS for more
details.
Dale,
This is kind of painful, but it may help. Run MRP again, with logging, and have it log MRP and scheduling. When it's done open up the basic log - I use a name like "MRPTestA", changing the letter each time I run it on a given day [I'm about where you are, so I'm doing it repeatedly today]. Then scroll down until you find the long lines of text. [It's a big file, but most of the lines are pretty short, so you don't actually have to read each one closely, which lets this be reasonably quick.] In there you should find at least a hint of the problem. The one I've had more than once is a routing resource problem, as I have more than one plant, and MRP gags on a routing that uses resources from a different plant. The Engineering Workbench doesn't prevent you from making this error, either.
Or, at the moment, I'm trying to find the 'missing revision for subassembly' problem. Naturally, the log doesn't tell me WHICH assembly is missing a valid revision.
Can you call your consultant vice Epicor?
Good luck.
Lynn Thomas
Senior Engineer
SAIC
317-357-4041 X255
I¹ll confirm this as well. We had issues in .405 with MRP hanging. I ran
the performance tuning suggestions, particularly making the schema holder
read-only and changing the indexes to non-clustered, and MRP has (knock on
formica) been rock solid ever since.
This takes an hour or so to get working. I screwed up the .pf file
settings the first couple of times as the settings are a little subtle.
-bws
> non-clustered.
I would suggest to first upgrade to 406A. I don't know of any specific issues with MRP, but in general 406 was buggy and after we went to 406A most of the bugs went away (although there were some new ones that showed up). This may help or it may not.
To: Vic Drecchio <Vic.Drecchio@...>
Cc: vantage@yahoogroups.com
Sent: Tuesday, December 9, 2008 1:54:42 PM
Subject: RE: [Vantage] MRP Crash
8.03.406
SQL
Dale Walker
www.lesueurinc. com
"Vic Drecchio" <Vic.Drecchio@ TIMCO.aero>
12/09/2008 12:51 PM
To
<vantage@yahoogroups .com>
cc
<dwalker@lesueurinc. com>
Subject
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of dswmaom
To: vantage@yahoogroups .com
way...)
water.
thx,
Dale.
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Also, in the .pf file you will want to make this change:
Original:
-Dsrv PRGRS_CONNECT,DSN=MFGSYS803,TXN_ISOLATION,1,ZPRGRS_UPDLOCK_HINT,0
Change to:
-Dsrv
PRGRS_CONNECT,DSN=MFGSYS803,TXN_ISOLATION,1,PRGRS_NATIVE_LOCKWAIT,32000
Also, if anyone else is already using the PRGRS_NATIVE_LOCKWAIT then make
sure you drop the number down to 32000 or less, Epicor reccomends 30000,
having it any more than that can cause the system to run in a loop forever,
never timing out at all since anything above 32000+change(I forget the exact
number) is not able to be processed so it assume it is 0, which means it
never times out. Many sites were set to 60000 upon installation, which is
why there may be a need for a change to anyone who is currently installed.
----- Original Message -----
To: <vantage@yahoogroups.com>
Cc: <dwalker@...>
Sent: Tuesday, December 09, 2008 2:08 PM
> non-clustered.
> Good luck.
> Page: 8723MPS
> XA803
> RECOMMENDATIONS:
> settings:
> OE 10.0B:
> OE 10.1B:
> this up:
> original values.
> implemented.
> Explorer Tool:
> After-image writer.
> everyone.
> the following:
> folder.
> Hyperthreading.
> issues.
> ABS(OLUTE) ABS
> abs
> ASC(II) ASC
> ascii
> INT(EGER) INTEGER
> convert
> MAX(IMUM) MAXIMUM
> MIN(IMUM) MINIMUM
> deleted.
> details.
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
On behalf of Dale Walker (Originator of this thread)
Thanks to all who replied to this thread !
The problem was that we needed to run the nullfixer.r program against
the database.
I did learn alot from the SQL tuning doc and I made the SQL Tuning
modifications, hopefully they will give us the best performance going
forward.
Regards to all who contributed.
Neil
> Original:
> -Dsrv
> Change to:
> -Dsrv
0
then make
30000,
forever,
the exact
means it
which is
installed.
> From: "Vic Drecchio" <vic.drecchio@...>
> Cc: <dwalker@...>
of our
> > non-clustered.
> > Good luck.
> > Page: 8723MPS
> > XA803
Progress
alone.
> > RECOMMENDATIONS:
Vantage
to the
> > settings:
> > OE 10.0B:
32000 -tok
> > OE 10.1B:
32000 -tok
effect
no
available
addressed in
higher) or
the
any from
use more
set
> > this up:
Tool.
Some
stopped
AppServers, then
failure to
more RAM
failures
patch
their
> > original values.
Tool can
resources,
take
Explorer
database,
Explorer
(below) is
> > implemented.
will
Steps for
Tool.
is
running
many
overflow,
> > Explorer Tool:
Tool.
is
acquire
resource's
Tool.
will
Tool.
writer and
> > After-image writer.
This
there are
8782MPS
changes
help
questions
problem.
then
control, for
> > everyone.
should do
> > the following:
> > folder.
In most
turn off
> > Hyperthreading.
previously
syntax
> > issues.
for
occur.
> > ABS(OLUTE) ABS
> > abs
> > ASC(II) ASC
> > ascii
> > INT(EGER) INTEGER
> > convert
> > MAX(IMUM) MAXIMUM
> > MIN(IMUM) MINIMUM
Companies
It is
> > deleted.
2005, if
issues
Microsoft issue
more
> > details.
must
access. )
Builder and
So out of curiousity, what caused the underlying condition that required
you to run this utility?
> the database.
> forward.
We are in the process of converting/incorporating our data from our
old MRP system into Vantage.
During this last conversion attempt we had some errors in fields that
came thru clean on previous conversions.
I suspect that there were some inconsistancies in the conversion
process that caused our MRP run to crap out.
The null fixer found a bunch of stuff and fixed it, now it seems
happy.
I also ran the null fixer against the previous conversion to see if
that would run "clean", it did NOT run clean so maybe there was
something specific about some table/field that made MRP gag.
I haven't done a complete post mortem to find exactly where the fault
occured but I will be sending the log files to Epicor for analysis.
Neil
--- In vantage@yahoogroups.com, "Brian W, Spolarich" <bspolarich@...>
required
against
> > the database.
going
> > forward.
