I had same issue in setting up a test server for 803.
The only thing I could figure was a mismatch between OpenEdge
versions installed on the different machines
Make sure they are identical - service pack wise and capability wise
.02 - Bernie.
.02 - Bernie.
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hello,
> I installed Vantage 8.03 on my laptop that is running Windows XP
SP2 so
> that I could work out of the office and wouldn't need an internet
> connection.
> I backed up our database from our Vantage server and restored it to
my
> laptop. When I try to start the database I get an error message that
> indicates that the database can't start. (Can't remember the exact
error
> but I will post it later if needed). I also noticed that once the
> database is restored I can't do anything to it. For example, I
tried to
> restore again and I tried to run a couple of proutil commands
against it
> and in each case a get an error that says that it can't find the
> "word-break table 2".
> Despite the obvious hardware differences and the different OS the
only
> thing that is different is that Vantage is installed on the server
in
> D:\epicor and is installed in C:\epicorserver on the laptop.
> Any idea of why I can't start the database on the server?
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
