Move elements on my Order Entry screen!
Good day my friends,
I´m trying to re-design the Order Entry Screen in order to have more space for the lines I´m typing in, but the Lines Detail Tab doesn´t want to move, any ideas?
Try the following:
Select the summaryDetailSheet1 you will see selectable squares… so you could move up or just change the location number directly in the properties. Then change it’s size…to fill…
Pierre
Why not use the list view in the Lines tab, it is the same thing.
