Most wanted features/solutions
You can only vote once in the whole topic though. Is that the intention?
That’s the functionality right now.
so choose wisely… :thinking:
@Banderson I think it’s only because the conversion that was run on the thread for the feature. I think moving forward, on a fresh thread, it should work properly so long as entries are not a response to a comment.
I think I found a better solution I have a feeling this will be a very popular thread. So perhaps have a suggestions category with up Vote on each individual topic may be a bit easier to digest and also each individual suggestion can be discussed individually. I’ll work on that this evening.
Ok @Banderson I added a new category called Feature Requests and Suggestions
Every topic in this category can be Voted On and sorted by votes. This allows to have 1 topic per suggestion and to bubble to most popular suggestions to the top. It allow allows individual discussions on each suggestion. It also allows you to vote for multiple topics.
I have moved some of these in this thread over there. If you made some feel free to move your own. Or re-create it over there.
Heads up @Bart_Elia, @erikj, @Edge, @Rich
8 votes -choose wisely :smiley:
Nope that’s going away.
If you are a Level 0 (Basic) user of the forum you get up to 10 votes. Everyone else can vote as much as they’d like… I set it pretty high.
This is done.
Mike, You mean Global Global Options :slight_smile:
I’ve been thinking about my original post. I’m thinking that the ability to duplicate and employee would be useful, even as a minimum. At least in that way you can hand off the adding of employees to HR without too much worry.
Not sure if there are any plugins for other payroll systems that would allow you to create an employee based on output from that. A Service Connect workflow perhaps? But you would need ESC for that :frowning:
*** Added to Feature Requests and Suggestions
We are listening - thanks for this jose
I just like a lot of these are on my internal wish list and a few new ones I am learning so appreciate the kick.
Keep it up folks!
It would be useful to have line numbers in the BPM “Enter Custom Code” editor that would correspond to the line numbers in the error message after saving a BPM C# code change.
Description:  There is at least one compilation error.
Details:
Error CS0103: The name 'rsiPre_Serial_No_c' does not exist in the current context [Update.Post.rsiCopyQuoteJobT.cs(145,130)]
Error CS0029: Cannot implicitly convert type 'rsiPre_Serial_No_c' to 'string' [Update.Post.rsiCopyQuoteJobT.cs(168,33)]
Program:  Epicor.Customization.dll
Method:  PrepareException
Line Number:  99
Column Number:  13
Server Trace Stack:     at
