I have been working on a dashboard customization but I have not been able to figure out a specific section that has me stuck. My dashboard queries the LaborHed and EmpBasic tables (sorting by employee name ascending) and simply shows all employees that clocked in through MES for a specific day and their hours worked on that clock in. My goal with this customization is to highlight the employee’s name field when there are duplicate entries back-to-back. For Example: Employee ‘Bob’ had 2 clock-ins today, resulting in 2 entries with different times and pay hours, i would like my customization to highlight the second occurrence of Bob in the table.
I first tried using the Wizard Row Rules with a Custom Condition but I could not figure out a way to prevent it from reassessing every time a row was selected (this entire dashboard is update-able so there will be a lot of row updates that will happen)
After suspending my attempt with row rules I have been trying a different path. I created a Form Event on AterToolClick using the wizard, I then have it call a custom function when the user has clicked the refresh tool (the dashboard does not auto-refresh so the user is forced to refresh to query). The custom function loops through all of the grid rows and attempts to change the SettingStyle if the current and previous grid row are for the same employee. I am trying to use the SetCurrentRowProperty() and it does work but not as intended - even though I believe I have set the EpiDataView’s current row with mainDV.Row = i
when I run the dashboard it will highlight the entire employee name column, not just the current row’s employee name.
private void DuplicateAssess(){
EpiUltraGrid mainGrid = (EpiUltraGrid)csm.GetNativeControlReference("123b945d-d2e9-4d5e-a27c-0414a1b7475a");
EpiDataView mainDV = (EpiDataView)this.oTrans.EpiDataViews["V_CTGI_UpdatePayHours_1View"];
for(int i=0; i<mainGrid.Rows.Count; i++){
//back checking - make sure within index range
if(i>0){
//check if this is a duplicate row (same employee) - change the style of that row/field
if(mainGrid.Rows[i].Cells["EmpBasic_Name"].Value.ToString() == mainGrid.Rows[i-1].Cells["EmpBasic_Name"].Value.ToString()){
//set the current row in the EpiDataView
mainDV.Row = i;
//attempt to change the current row property
mainDV.SetCurrentRowProperty("EmpBasic_Name", SettingStyle.Warning);
Does anyone have any ideas as to why this is or how I could accomplish this in a different way? (I know life is way easier with Row Rules but I could not get them to work for this situation)
Thank you!
