Modifying Report Data Definition for Job Traveler
Thanks to both of you for your replies. After posting my question I
did try another route and that worked. I had hoped to make it
simpler by using the Calculated field CustID in the JobHeader table
but I guess that must not be possible.
What I did was link the OrderHead table to the Job Ship Table then
the Customer Table to the OrderHead table.
Brian Stenglein
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Don't forget that company = company needs to be in every
relationship.
> It appears that custnum is not in any of the tables in your Data
> Definition.
> This is what I would do:
> 1. Add table CustXPrt
> 2. Add relationship Parent Table JobPart to Child Table CustXPrt.
> JobPart.Company = CustXPrt.Company
> JobPart.PartNum = CustXPrt.PartNum
> 3. Now add table Customer.
> 4. Add relationship Parent Table CustXPrt to Child Table Customer.
> CustXPrt.Company = Customer.Company
> CustXPrt.CustNum = Customer.CustNum
> That should work to get information from your Customer table onto
> your Job Traveler form.
> If you are following the steps in Epicor's AnswerBook #
4778MPS, "CR
> Modifying a Crystal Report form in V8.xx", you shouldn't get any
> errors. You can download Answerbooks free from the Epicor website
by
> logging on and searching for them in the Epicor Search field.
> Lynn
> --- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@> wrote:
> > You want to find the field CustNum...not custID. That will help
> link
> > your tables.
> > Look at the other tables available in the definition for this
link.
> > HTH,
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Brian Stenglein
> > Sent: Thursday, October 16, 2008 2:02 PM
> > Subject: [Vantage] Modifying Report Data Definition for Job
Traveler
> > I am trying my first modification to a "Crystal Form" in
8.03.400,
> the
> > Job Traveler. We have some customer specific notes in the
Customer
> VB
> > form fields Character02 and Character03 that we have printing on
> our
> > Vantage 6.1 Traveler. I need to get that data on the 8.03.400
> > Traveler. I have created a custom copy of the Traveler and the
> Report
> > Data Definition. I've figured out how to add a field (BubbleNum)
> from
> > a table (JobMtl) that already existed in the definition. Now I
need
> to
> > add a table (Customer) to the definition.
> > The JobHead table contains a calculated field for CustID that I
was
> > hoping to be able to use to link to the Customer table. I'm not
> sure
> > if it's possible to link with a calculated field or not, but when
I
> > added the customer table and added a relationship and tried to
> chose
> > the relationship field CustID isn't available.
> > How would you advise linking the Customer Table to the Job
Traveler?
> > Thanks,
> > Brian Stenglein
I am trying my first modification to a "Crystal Form" in 8.03.400, the
Job Traveler. We have some customer specific notes in the Customer VB
form fields Character02 and Character03 that we have printing on our
Traveler. I have created a custom copy of the Traveler and the Report
Data Definition. I've figured out how to add a field (BubbleNum) from
a table (JobMtl) that already existed in the definition. Now I need to
The JobHead table contains a calculated field for CustID that I was
hoping to be able to use to link to the Customer table. I'm not sure
if it's possible to link with a calculated field or not, but when I
added the customer table and added a relationship and tried to chose
How would you advise linking the Customer Table to the Job Traveler?
Brian Stenglein
You want to find the field CustNum...not custID. That will help link
your tables.
Look at the other tables available in the definition for this link.
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Brian Stenglein
Subject: [Vantage] Modifying Report Data Definition for Job Traveler
Brian Stenglein
Don't forget that company = company needs to be in every relationship.
Definition.
If you are following the steps in Epicor's AnswerBook # 4778MPS, "CR
errors. You can download Answerbooks free from the Epicor website by
Lynn
link
> your tables.
> HTH,
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of Brian Stenglein
the
VB
our
Report
from
to
sure
chose
> Thanks,
> Brian Stenglein
