What a concept to reconfirm a PO or reacknowledge an Order. To things
Vantage can't do.
The easiest fix I have been able to come up with for not printing closed or
void purchase order line items & releases and for not printing Order
Acknowledgement line items and releases is to add a some VBFORM fields to
the Header Record and Line Record Levels.
I put in both a PRINT FROM REQUEST DATE and THRU REQUEST DATE. I then added
four numeric fields for SKIP RELEASE NUMBERS this gives me a couple of ways
of not printing closed releases. I also don't print items that the qty is >=
the release amount.
My Acknowledgement form has the following formula under Details Line D under
SUPPRESS:
{orderrel.JOBSHIPQTY} + {orderrel.STKSHIPQTY} >= {orderrel.REQQTY}
OR {orderrel.NEEDBYDATE} < {orderdtl.ODDATE01}
OR {orderrel.NEEDBYDATE} > {orderdtl.ODDATE02}
OR {orderrel.ORDRELNUM} = {orderdtl.ODCHAR01}
OR {orderrel.ORDRELNUM} = {orderdtl.ODCHAR02}
OR {orderrel.ORDRELNUM} = {orderdtl.ODCHAR03}
OR {orderrel.ORDRELNUM} = {orderdtl.ODCHAR04}
Someday vantage will pass the CLOSED and VOID fields to fix this until then,
this has to rank in my TOP 5 pet peeves that Vantage will not fix.
Patrick Winter
Sent: Monday, March 19, 2001 5:58 PM
To: 'vantage@egroups.com'
Subject: [Vantage] modified PO form
has anyone modified the standard PO form to either delete closed releases,
or at least mark them as closed? as long as a line item is open, all of the
releases print open or not. this gets a little confusing for the supplier
when we reschedule something and confirm it with a hard copy of the PO.
if anyone has made modifications lake this and would be willing to share, we
would sure appreciate it. we are on version 4.00.904.
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Vantage can't do.
the release amount.
SUPPRESS:
Patrick Winter
