Modified in field search
Good morning team. How can i modified the part search on the wild card on part maintenance
That search feature is called Zone BAQ. It is maintained in Extended Properties, where you select the table and field (Part and PartNum in this case) and point to a BAQ that defines what columns show and what is or is not included in the returned list. That Zone BAQ then shows up on any screen with the field, including grids.
i tried this and it didnt work any idea?
I found the issue i had to change the extended properties and then also go into customization mode and do it in code idk why but that is how it worked for me
That’s not anything I have done. Glad you figured it out.
