Doing a test upgrade from 10.1.600 to 2021.2 and we have no Home Page Layouts.
User Account Security Maintenance shows no layouts to select from either:
We get an error trying to log into Kinetic Home page:
BUT, we do get the Kinetic Home Page via the browser:
Things we’ve tried:
Enabled Processes | Home Page in Menu Maintenance (removed Security Manager Only)
Ensured Token Authentication is enabled (Active Homepage and EDD work in the browser )
utaylor
(Utah Taylor)
July 1, 2022, 3:50pm
2
Mark, what does your client sysconfig file look like for that environment?
Specifically, is your homepage URL properly configured?
utaylor
(Utah Taylor)
July 1, 2022, 3:54pm
3
Also, if you are using an SSL that has an address different than your appserver:
App server URL: https://servername/Test
SSL: mycoolsslname.com/Test
Then you need to make sure that the appserver node and the homepage node in the sysconfig file match that of your SSL.
utaylor
(Utah Taylor)
July 1, 2022, 3:55pm
4
My last two comments are in response to the “can’t log in” message. I don’t know about the home page layouts.
Good thought. I copied the Homepage URL from the config file and pasted it into the browser and get a login screen.
The error pops up after the authentication is complete. I’m thinking a conversion didn’t run or I would be able to set a default layout. (I also filed a ticket on EpicCare not seeing anything there either…)
