I’m trying to print a Misc Shipment pack list. It shows a message “Report Submitted for Previewing” or “Report Submitted for Printing,” but then nothing happens. I’m able to print preview and print from other processes, like PO Entry. I’ve cleared client cache, restarted Epicor, and rebooted my PC, but still nothing. This happened once before, but our I.T. Manager who fixed it is out of the office. Any ideas?
Check the System Monitor.
In your system tray find the E icon for Epicor System Monitor. Double click the icon and when it opens, go to the Active Tasks tab to see if your report is still running. If not, go to the History Tasks tab to see if there is a row highlighted in yellow. These are errors. Click on the error row and then go the Report/Task Logs sub-tab. This will show any details about why the report failed. Most commonly because the report returned no records.
This should at least help you figure out if the report is stuck running or if it is failing at some point. Let us know what you find there.
I see you are also using a customized report. If an error occurs in a calculated report field, this will cause the report to fail. Many times, this is due to a field calculating with a 0 or a null (divide by 0 or divide by null).
Thanks! Here’s what I found:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask:
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: The Hidden expression for the tablix ‘Tablix2’ contains an error: Input string was not in a correct format. —> Microsoft.ReportingServices.Diagnostics.Utilities.RSException: The Hidden expression for the tablix ‘Tablix2’ contains an error: Input string was not in a correct format.
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.InternalRender(String Format, String DeviceInfo, PageCountMode pageCountMode, Stream& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.Render(String Format, String DeviceInfo, PageCountMode pageCountMode, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.WebServer.ReportExecutionService.Render(String Format, String DeviceInfo, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 633
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 142
at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.b__0() in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func2 messageBuilder) in C:\_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39 at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func
1 timedAction) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 264
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func2 reportsRenderer, Action
1 fillSysRptLstRow, Action2 processReport, Func
3 filterTableAttachmentsFunc) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 59
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func2 executeCommand, Func
2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
at Ice.Core.RptTaskBase1.XMLClose() in C:\_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 229 at Erp.Internal.SR.MscPackSlip.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\RL10.2.500.0\Source\Server\Internal\SR\MscPackSlip\MscPackSlip.cs:line 315 at Ice.Core.TaskBase
1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 83
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 117
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 59
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\RL10.2.500.0FW\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\RL10.2.500.0FW\Source\Server\Services\Lib\RunTask\RunTask.cs:line 452
So, this may be beyond what you are willing to dive into. Basically, there is an issue with a string in the tablix2. One of the fields is being hidden based on an expression. If you want to play around with this, make sure you are working in Pilot. To get started, open the rdl, and see if you can find the hidden field expression. Simply turn off the hidden field expression and show it always. This may not be your desired functionality, but it can at least show you the report.
If the report always worked well in the past, but it isn’t working today, then something that feeds that report is causing an issue. Either a custom UD field is not populated somewhere, or some other critical information is missing.
Good luck!
