Wayne
I am assuming that you found the MFG-VAR on your inventory/wip report?
What is the reference, that usually can point you in the right direction to
determine where it came from?
At 03:18 PM 9/7/01 -0500, you wrote:
>We do use receiving inspection, but haven't encountered this because we usehave already linked your email address to a yahoo id to enable access. )
>it as method to decide IF an outside services or material transaction can be
>paid. Until it is released from inspection, the invoice doesn't even get
>entered into Vantage, let alone paid.
>Yes, I was referring to back or post-dated transactions. Particularly, the
>miscellaneous charges where the ADJ-PUR transactions could be handled by
>Vantage much more effectively (accurately). Especially frustrating at month
>end, when the A/P clearing account is affected by prior month transactions,
>which are received in the prior month, invoice entered into a prior month
>group and posted with its prior month invoice date, but since the
>transaction is entered into the prior month group in the current month,
>Vantage posts the adjustment to the current month. An August receipt of
>8/31 is not going to have the invoice on site on 8/31 except in rare
>situations. Some August invoices will need to be entered in Sept. Such
>transactions really play havoc with GAAP, and balance sheet account
>reconciliation. Of course, one solution is to not enter 8/31 invoices after
>8/31 and just write G/L entries. I view that type of workaround thought
>process as a decade or so backwards and generally inadequate. Not
>reconciling the A/P clearing account at all, or not to the penny, are other
>options.
>But not good options. Call #720661MPS.
>We are on Version 4, but Support assures me that Version 5 behaves the same
>unacceptable way.
>Yup, the soap box is travelling again today. Sorry not to have helped find
>a clue to your mystery. Since your dates are reasonably close, it sounds
>like we'll need to look elsewhere. You use Last cost and the closed job was
>affected. Hmm. I'll have to think on it, haven't encountered it before.
>Have a good weekend.
>Deb
>-----Original Message-----
>From: Wayne Cox [mailto:wmc@...]
>Sent: Friday, September 07, 2001 1:54 PM
>To: vantage@yahoogroups.com
>Subject: RE: [Vantage] MFG-VAR on closed jobs
>At 02:13 PM 9/7/2001 , you wrote:
>>Have you already checked the system dates in Job Tracker, in addition to
>>the transaction dates?
>Yes, they are all reasonably close. No back- or post-dated transactions,
>if that's what you mean.
>> I've had trouble with how Vantage handles ADJ-PUR
>> transactions. Wondering if you are encountering similar difficulties
>> with MFG-VAR transactions.
>I found a really confusing thing with ADJ-PURs that might explain what
>you're seeing. Do you use receiving inspection? If the item is in
>inspection when the Adj-Pur is generated, the adjustment goes to the
>inspection GL account, rather then WIP or inventory. There's no flag in
>the PartTran record to tell which one it used, except the account number
>itself. If you try to sum up all the PartTran records for a job, you'll
>get a total that doesn't match the job's total, *unless* you exclude the
>ones that have the inspection inventory chart number.
> -Wayne
>[Non-text portions of this message have been removed]
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>(1) To access the Files Section of our Yahoo!Group for Report Builder andCrystal Reports and other 'goodies', please goto:
>(2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
