Kinetic UX. Customer Credit Manager layer. Activity > Orders grid. I added an event which is triggered by Column Changed event. Works perfectly. In next step I added a View Options. I just copied everything from Grid Model > Provider Model and created two entries All and Filtered (in Filtered I added a Client Filter. View Options are working fine but event triggered by Column Changed is not fired any-more. Another bug? Can someone please recheck and confirm. @hmwillett maybe you if you have a time? Of course when I removed View Options my even is fired again.
It should not have any impact - but column I am changing it’s a drop down filled from UDCodes bind to custom field on OrderHed. That’s why I mentioned a specifci from “Customer Credit Manager” as I am suspect that it might be related to that form.
Anyway I should soon have access to 2023 and for sure I will recheck.
EDIT: Is your grid a total custom grid or you modified one which already exist on the form? I modified existing one - it might matter.
I used a grid that was created from the App Wizard, soooo kind of both? lol
