Glad to hear it!
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tim Hollingsworth
Sent: Thursday, May 31, 2012 1:48 PM
Subject: RE: [Vantage] MES Pre-approval
Finally go a chance to put this in and it works great, Thanks!
Tim Hollingsworth
Cost Accountant
Sun Country Industries
(505) 998-1980 (office)
(703) 867-4400 (cell)
thollingsworth@...<mailto:thollingsworth%40suncountryindustries.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Rob Bucek
Sent: Tuesday, May 22, 2012 10:01 AM
Here is what you should do to make this work...
On the Labor BO, choose the update method
Create a preprocess BPM
Condition should be Number of rows in the [designed] query in not less
than 1
In your designed query, paste this code in..
for each ttlabordtl where ttlabordtl.rowmod = 'A' and
ttlabordtl.labortype = 'P'
this ensures this BPM will not fire for every labor transaction under
the sun that doesn't have anything to do with completing production
quantities against operations.
Under actions choose synchronously Execute 4GL code - execute code below
Paste the following code in the field
for each ttlabordtl where ttlabordtl.RowMod = 'A' no-lock.
find first joboper where joboper.company = ttlabordtl.company and
joboper.jobnum = ttlabordtl.jobnum and joboper.AssemblySeq =
ttlabordtl.AssemblySeq and joboper.OprSeq = ttlabordtl.OprSeq.
If avail joboper Then Do:
If joboper.QtyCompleted + ttlabordtl.LaborQty > joboper.RunQty then
{lib/PublishEx.i &ExMsg = "'There have already been ' +
string(joboper.qtycompleted) + ' parts claimed complete. The Production
quantity required for this operations is ' + string(joboper.runqty) +
'.' + ' Your additional quantity of ' + string(ttlabordtl.laborqty) + '
will result in an over reported quantity'"}.
End.
End.
This solution works in 8.03.409c, but I can't fathom any reason it won't
work in 9 unless they changed column names.
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Brian Roberts
Sent: Tuesday, May 22, 2012 10:32 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Not sure how hard it will be, haven't done that one myself... but if
you've just taken a couple classes, time to practice...
To get you started: you'll probably want a method BPM on
Labor.EndActivity pre-processing (I think - do some tracing to make
sure). The quantity they are reporting should be in the
ttLaborDtl.LaborQty field, and start by just displaying an informational
message with that quantity in your BPM (no condition, just that one
action - do in your test environment of course). You'll need to figure
out where the job quantity is available, try writing the full dataset
during tracing or looking in the data dictionary. Add a condition for
LaborQty > job qty and when that is working properly, change your action
to raise exception instead of info message. Raising an exception in
pre-processing will abort the end activity before the data gets saved.
Brian.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Sent: Tuesday, May 22, 2012 11:14 AM
Hello Brian,
I would love to set up a BPM preventing a quantity greater than present
on the job. I took a couple of the classes on BPMs at the conference,
but have not done one yet, how hard is this one to set up?
Tim
On
Behalf
Of Brian Roberts
Sent: Tuesday, May 22, 2012 8:58 AM
You could turn off the "auto receive to inventory" on the last job
operation, and do a manual receipt from manufacturing. Of course, this
could lead to incorrect inventory if that manual entry is delayed or
that a typo is made in that quantity.. six of one error, half dozen of
another J
Here's another idea: a BPM on end activity that prevents reporting a
quantity, say greater than the job quantity.
Brian.
Behalf
Of jobando018
Sent: Tuesday, May 22, 2012 10:20 AM
Subject: [Vantage] MES Pre-approval
Good Morning Group,
Is there a pre-approval stage after a user has ended an activity in MES?
We would like to see all the production activities submitted for a given
day and approve the quantities before moving them into inventory.Even if
there is not a pre-approval stage, are there any process in place that
you have implemented to oversee MES transactions?
Manufacturing is concerned that all production is being moved into
inventory right after a MES user ends an activity. It can lead to
incorrect inventory if production is reported incorrectly.
Epicor 9.05.607a
SQL 64-bit
Windows Server 2008
Rob Bucek
FAX: (715)284-4084
Tim Hollingsworth
Cost Accountant
Of Rob Bucek
than 1
End.
End.
Rob Bucek
FAX: (715)284-4084
Brian.
On Behalf
Hello Brian,
Tim
On
Behalf
Of Brian Roberts
another J
Brian.
Behalf
Of jobando018
Good Morning Group,
Epicor 9.05.607a
SQL 64-bit
Windows Server 2008
