MES Job clocking onto wrong employee
Hi,
We have an intermittent problem which is difficult to replicate. Sometimes an employee clocks onto a job in MES then, shortly after, when another employee clocks onto a different job (on the same PC) the second job also gets assigned to the first employee. Has anyone else had this problem? If so, did you manage to fix it?
Alison
Hi Alison,
We utilize the MES a ton. The only time I have seen this happen in the past is when the first employee does not “log out” of the MES after starting their operation. The second employee then starts their activity on the first employees log in. I realize this may not be the case for you but thought you may look into it.
Hi Todd,
I’m assured that employees always log out.
Alison
Apparently this is a bug which should be fixed in version 11.1.100
