Thanks, those were helpful.
The problem I'm running into now is that I've had to convert that VB code into C#. The syntax is correct, but when I click the button I'm getting an error. I'm working with Epicor support too see if the fix we received is not working correctly.
But basically we received a patch that is supposed to make the serial matching form available to be launched in MES. I applied the fix as instructed.
--- In vantage@yahoogroups.com, "justint94536" <justint@...> wrote:
> Easiest way is to log into EpicWeb and do a search for MES Customization.
> You're looking for answer book #'s 6539MPS and 4306ESC. It gives step by step information to do exactly what you want.
> --- In vantage@yahoogroups.com, "swenson.justin" <swenson.justin@> wrote:
> > I'm looking to add a custom Serialization matching screen available in full blown Epicor to MES. I received a patch from Epicor that should allow Serialization matching to be added to MES, but I don't know 2 things. But I'm receiving an error when launching it.
Error is below:
Application Error
The process caller failed to invoke method LaunchForm in Epicor.Mfg.UI.App.Launch in Eicor.Mfg.UI.SerialMatchingEntry.dll
Justin
> > (1) How to create a new MESControl, so I can bind the screen to an MES button.
> > (2) How do I allow this new custom MES screen to become the default that's opened? I'm not completely understanding the process as described by Epicor's application help.
> > Thanks,
> > Justin
