MES Customization
E
Sent via BlackBerry by AT&T
Sender: vantage@yahoogroups.com
Date: Mon, 12 Jul 2010 14:32:13
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: RE: [Vantage] MES Customization
Don't "hide" the buttons.
Set the size to 0,0 and they will disappear then.
Of VantageUser13
Sent: Monday, July 12, 2010 2:25 PM
Subject: [Vantage] MES Customization
I will need on the MES, to hide a button. I go on my customization, and
on load form i write this line : btnStartActivitySetup.visible = false
but doesn't work. I have all the time the error message. If possible in
the customization to hide the button ?
Vantage 8.03.408b
Does anyone know how to customize the MES Screen for Vantage 8.0? We have seen it done, but epicor seems to be kinda secretive about it and we cant seem to get any information on how to do it...
Brad
Its not at all a secret. The basic steps are outlined in the Vantage
Help under the "MES Customization" topic.
There's also some Answerbooks on EpicWeb that provide some more
detail.
https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?/ePortal
/ABDetail&rs:Command=Render&rc:Toolbar=true&Card_ID=6035MPS&Answerbook=C
lientele+Change+Requests
-bws
Of brad.ebright
Sent: Monday, September 27, 2010 1:41 PM
Brad
Has anyone come across any notes/instructions for customizing MES? I'd like to give certain users access to more than what's available. For example, in Part Tracker (or anywhere the part is displayed) i'd like them to be able to right click and select open with Part Advisor to see what jobs are open for the part. In addition, I can't seem to get the main buttons to be un-grayed out. Thanks!
Your current administrator has to release you the rights for Customization access. Once you have them you can access this in the developer mode. If you need instructions on how this is done email me directly.
Michael Brown
Master Scheduler
D&S Manufacturing
mbrown@...
715-284-5376 Ext. 344
www.dsmfg.com
Sent: Tuesday, November 15, 2011 1:17 PM
Â
Note that the MES license only allows access to certain screens, I think
there's a list somewhere in the documentation. You can add a button to
a screen, but have it fail to open due to licensing.
Brian.
Of vantagewow
Sent: Tuesday, November 15, 2011 2:17 PM
This is a follow-up of a post I did a few weeks ago, still running into the same issue. Currently on Epicor 9.05.606.
Looking to launch from a button in MES an entry screen that's not listed as an MESControl. Epicor gave us a one-off that allowed us rights within our license to launch SerialMatching from MES (which I hear is standard in 9.05.702).
There's a solution to do this in the answerbooks on EpicWeb, but it's for Vantage and it's in VB. I want it in C# (I used a free converter for this), and I know that there are at least 3 code differences to make this work in E9 compared to Vantage. Where I'm stuck (or at least the error I'm receiving) is also in the answerbook for vantage, but the example is launch a report.
The issue is setting LaunchFormOptions.ValueIn = "[The report ID]", but because I'm not launching a report I don't have another ID to give. Yet this is the error I'm receiving, that I need to set a value for LaunchFormOptions.
Here's my code:
// Custom code for MESMenu
// Created: 6/20/2012 10:42:55 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.BO;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
public class Script
private EpiButton withEventsField_btnSerialMatching;
// Begin Custom Code Disposal
// End Custom Code Disposal
private void btnSerialMatching_Click(object Sender, EventArgs args)
ProcessCaller.LaunchForm(MESMenu, "JCGO3180");
private EpiButton btnSerialMatching
get
return withEventsField_btnSerialMatching;
set
if (withEventsField_btnSerialMatching != null)
withEventsField_btnSerialMatching.Click -= btnSerialMatching_Click;
withEventsField_btnSerialMatching = value;
withEventsField_btnSerialMatching.Click += btnSerialMatching_Click;
private void MESMenu_Load(object sender, EventArgs args)
//// Add Event Handler Code
btnSerialMatching = (EpiButton)csm.GetNativeControlReference("fe187107-b719-4a3d-96a8-5f8505ea65ae");
btnSerialMatching.ReadOnly = false;
And the error:
Error Detail
The process caller failed to invoke method LaunchForm in Epicor.Mfg.UI.App.Launch in Epicor.Mfg.UI.SerialMatchingEntry.dll
Stack Trace
at Epicor.Mfg.UI.FrameWork.PCallReflector.InvokeReflectedMethod(MethodInfo Method, Object Object, Object[] MethodParams, String className, String assemblyName)
at Epicor.Mfg.UI.FrameWork.PCallReflector.LaunchDotNet(String assemblyName, String className, Hashtable ctorList, String methodName, Hashtable methodList)
Inner Exception
Exception has been thrown by the target of an invocation.
Inner Stack Trace
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
Inner Exception
Unable to cast object of type 'Epicor.Mfg.UI.FrameWork.LaunchFormOptions' to type 'Epicor.Mfg.UI.App.SerialMatchingEntry.SerialMatchingArgs'.
Inner Stack Trace
at Epicor.Mfg.UI.App.Launch.LaunchForm(Object LaunchObject)
Any assistance or ideas to try would be great.
Justin
You don't have an LFO at all..
Is JCGO3180 the Menu Item for Serial Number Entry?
try this
ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UI.YourSerialNo.dll");
FYI that's not the actual DLL but you cna find the the name
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Thu, Jul 19, 2012 at 11:21 AM, swenson.justin
<swenson.justin@...>wrote:
> JCGO3180
Yes, JCGO3180 is the menu item for the SerialMatchingEntry, it tries to call the Epicor.Mfg.UI.SerialMatchingEntry.dll, but then tells me I need something set for the LaunchFormOption, I have not idea what would need to be set though and the only similar example of this I found is when calling a BAQ report, you use the report ID set to LaunchFormOption.ValueIn = "[reportID]".
I tried what you set below. Are you saying just replace what I have for the ProcessCaller? That's what I did and the button didn't launch at all.
I'm working with the developer who gave us the one-off and his only suggestion thus far was to point me to the answerbook item for Vantage that I mentioned earlier...
> try this
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > JCGO3180
Since you're opening a serial number form, trying setting ValueIn to
that serial number. Or maybe the part number? But unfortunately that's
just a guess.
Its possible that particular form requires something more complex.
Below is some sample code (in E9.05 C#) for calling the packing slip
print form, which requires two values passed in - might be useful as an
example. Either Epicor or the developer you worked with should be able
to tell you exactly what you need to pass in.
Brian.
System.Collections.ArrayList arrParams = new
System.Collections.ArrayList();
arrParams.Add(packnum); // packing slip on
selected row
arrParams.Add(false);
// invoiced flag (unused)
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.ValueIn = arrParams;
lfo.IsModal = true;
object result = ProcessCaller.LaunchForm(oTrans,
"Epicor.Mfg.UIRpt.PackingSlipPrint", lfo, true);
Of swenson.justin
Sent: Tuesday, July 24, 2012 11:49 AM
Subject: [Vantage] Re: MES Customization
all.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
> try this
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > JCGO3180
9.04.507a
I am trying to do my 1st MES customization. I am using one of the buttons on the supervisors menu that has not been used. I have created customization over EmpBasicEntry.dll through the normal customization process and put it on a menu with an id of UPSHPE. I have changed the Epibinding to "MESControl.Employee Fix". I have changed the text to "&Fix Employee Log in Error". I have changed Data - Tag to "UDSHPE" (this is the menu id that has my customized program and the customized version. Not sure this is needed, but I am trying to match one of Epicor's working buttons.) I have created in Process Calling Maintenance a custom process - Called Process Reference = "Employee Fix", and Menu ID = "UPSHPE".
While still in developer mode my button looks ok. When I click on the button I get the message - "No Menu ID found for MESControl.Employee Fix".
Any ideas on what I am missing?
TIA
You have to actually write the code behindd for the Click Event on the
button and use the ProcessCaller.launchform to launch the form you want.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Jul 17, 2013 at 1:49 PM, mike.numbers <mnumbers@...> wrote:
> 9.04.507a
> TIA
Hard Code the ProcessCaller.LaunchForm("UPSHPE") On the button click event.
Michael Brown
Master Scheduler / Programmer
D&S Manufacturing
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mike.numbers
Sent: Wednesday, July 17, 2013 12:49 PM
9.04.507a
TIA
I am not experienced in writing code for Click Events or using the
ProcessCaller. I learn from examples. I am looking at one of the existing
buttons on the MES (Order Tracker) and trying to match my button with
theirs. If I look at the Script Editor for Order Tracker, I don't see
anything added. I am not familiar with using the wizards, but l looked to
see if something would make sense to me and nothing did. Do you know of an
example I could follow. Basically I want to run a program that has a
customization version when the button is selected.
Jose Gomez
Sent: Wednesday, July 17, 2013 1:55 PM
To: Vantage
Subject: Re: [Vantage] MES Customization
*Jose C Gomez*
*Software Engineer*
E: jose@...
> 9.04.507a
> TIA
Vantage 8.03.09c, vb code:
Private Sub btnReprint_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnReprint.Click
'// ** Place Event Handling Code Here **
End Sub
In Vantage, customization mode, go to the event wizard tab, choose epibutton from first drop down, your button from second drop down, click from the third drop down. I do not have Epicor 9 to see the options, but they may be similar...
Then search this group for _Click for example...To see if there are any code examples for the process calling....
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Numbers
Sent: Wednesday, July 17, 2013 1:44 PM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...<mailto:jose%40josecgomez.com>
On Wed, Jul 17, 2013 at 1:49 PM, mike.numbers <mnumbers@...<mailto:mnumbers%40cignys.com>> wrote:
> 9.04.507a
> TIA
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
I would suggest you download a copy of the ICE 2.5 User experience and Customization Guide from Epicor Website, that would give you at least a few good hints to start writing code in Epicor. There's an example of how to use the process caller in it.
Christian
> Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > 9.04.507a
> > TIA
In trying to follow the wizard, I went to event wizard, chose epibutton,
the next drop down is titled "Custom Control" and there are no choices for
this one. The next drop down is "Available Control Events" and there are no
choices for this either.
Karen Schoenung
Sent: Wednesday, July 17, 2013 2:58 PM
End Sub
similar...
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
<mailto:mnumbers%40cignys.com> <mailto:mnumbers%40cignys.com>> wrote:
> 9.04.507a
> TIA
Sounds similar...Did you create a button and save it ?(you have to have a custom button - you can hide the original one by making visible = false)
Sent: Wednesday, July 17, 2013 2:05 PM
Karen Schoenung
End Sub
similar...
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...<mailto:jose%40josecgomez.com> <mailto:jose%40josecgomez.com>
> 9.04.507a
> TIA
This is from a POST I did on How to add a dashboard to MES. Only difference is that your MENU ID is Order Tracker
Version: 9.05?
Add the dashboard to your main menu.
Write down the MENU ID that you created. Ex. DASH0001
Under the properties for the MES Icon, change -MES to -MESC
Start the Application.
Click your current Customization for MES and open
Right click on one of your buttons and select CUSTOMIZATION
Choose your Tab to place the button.
Tools> Tool Box
Click EPI BUTTON
Add your button somewhere in the screen. Align and size button
Click on new button to display properties.
Under MISC, change TEXT; Ex. SHIPPING DASH
Under MISC, change NAME; epiBtDASH0001 (optional)
SAVE
Go to WIZARDS tab > Event Wizard
Control Type Filter: EPIButton
Custom Control: epiBtDASH001
Available Control Events: CLICK
Add using the arrow button; epibtDASH001_Click should be highlighted and the following displayed:
Private Sub epibtDASH0001_Click(ByVal sender As Object, ByVal args As System.EventArgs)
' ** Place Event Handling Code Here **
End Sub
Click on Update Selected Event Code (bottom right Corner)
Now go to the Script Editor Tab and look for the code you just pasted via the last step.
Add:
ProcessCaller.LaunchForm(MESMenu,"DASH001")
Should look like this:
End Sub
Save, close, remove the -MESC and leave it as -MES.
Start application and that is it.
Miguel A. Santillan
Compass Components, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karen Schoenung
Sent: Wednesday, July 17, 2013 12:23 PM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Numbers
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
Karen Schoenung
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
End Sub
similar...
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...<mailto:jose%40josecgomez.com><mailto:jose%40josecgomez.com> <mailto:jose%40josecgomez.com>
On Wed, Jul 17, 2013 at 1:49 PM, mike.numbers <mnumbers@...<mailto:mnumbers%40cignys.com><mailto:mnumbers%40cignys.com>
> 9.04.507a
> TIA
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
I used an existing button. I will create a custom button and try it.
On vacation until the 29th. Hope I can remember this.
Mike
Karen Schoenung
Sent: Wednesday, July 17, 2013 3:23 PM
Behalf Of
Karen Schoenung
End Sub
similar...
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
> 9.04.507a
> TIA
