MES Customization
I'll send you the info offline.
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...> wrote:
> The second one seems to be the one that applies to what I'm trying to do.
> ~Charlie
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Lynn
> Sent: Tuesday, March 31, 2009 9:08 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: MES Customization
> Charlie:
> There are 3 AnswerBooks on MyEpicWeb for Vantage 8.x that pertain to
> customizing MES.
> AnswerBook 5213MPS "How do you customize the main MES menu and set to use it
> instead of default"
> AnswerBook 6035MPS "How to customize programs within the MES menu"
> AnswerBook 6539MPS "MES How to program the blank buttons or reprogram
> existing ones"
> I think that you already have 2 of these AnswerBooks already. Which one do
> you need now?
> Lynn
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
> Wilson" <foamdesigncsw@> wrote:
> > It's global so I was going to try your method first and see what I get
> thank
> > you.
> > ~Charlie
> > _____
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Behalf Of
> > Rob Bucek
> > Sent: Monday, March 30, 2009 5:27 PM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > Subject: RE: [Vantage] MES Customization
> > Thanks! That's why I prefaced my statement with a question. I can be
> > slow on the pick up. Ours is a single site, single company environment
> > so it does simplify it for us a bit.
> > Charlie - what type of deployment are you looking for? A global change
> > or specific to a particular plant or company?
> > Rob Bucek
> > Manufacturing Engineer
> > PH: 715-284-5376 ext 311
> > FAX: 715-284-4084
> > <http://www.dsmfg. <http://www.dsmfg. <http://www.dsmfg.com/> com/> com/>
> > (Click the logo to view our site)
> > ________________________________
> > Behalf
> > Of Brian W. Spolarich
> > Sent: Monday, March 30, 2009 4:20 PM
> > Well it depends on your requirements.
> > If you're in a single company environment or can globally change what
> > gets invoked for a given MES button your solution is simpler. :-)
> > If not, then you need to do what I'm doing.
> > At least that was my thought process. I'm hardly an expert.
> > -bws
> > Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> > Picometrix
> > bspolarich@advanced <mailto:bspolarich%40advancedphotonix.com>
> photonix.com
> > <mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
> > www.advancedphotonix.com
> > -----Original Message-----
> > <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of Rob Bucek
> > Sent: Monday, March 30, 2009 5:11 PM
> > Did I misunderstand what he was after? We have a customized end
> > activity screen as well but I didn't have to customize that button or
> > add any vb code in any shape or form to launch my customized screen....
> > That solution seems more complicated than it needs to be.
> > Rob Bucek
> > FAX: 715-284-4084
> <http://www.dsmfg.
> > <http://www.dsmfg. <http://www.dsmfg.com/> com/> com/> >
> > Behalf
> > Sent: Monday, March 30, 2009 3:45 PM
> > Ah, okay. You want to have an MES button launch a customized version of
> > an existing screen.
> > So here's the deal. I'm going to assume that you're successfully able to
> > create a customization to the base MES screen and launch it via a
> > customized .mfgsys file as is described below in the message history. I
> > also assume that you've created and saved the customization on the
> > screen.
> > 1. First, you have to create a subprocess non-menu item for the
> > customized program you're going to launch from MES. For example, one of
> > my sites wanted a customized version of Job Tracker. So I did the
> > following:
> > A. In Sub Process Maintenance, create a new subprocess. Give it an ID
> > (e.g. UDPMJT01) and jot that down, and a security id (SEC000 is usually
> > good enough: that's the security ID of the top-level menu node). Program
> > Type: Non-Menu Item. Program: The dll of the program you're going to
> > launch (e.g. Epicor.Mfg.UI.JobTracker.dll). If you're not sure look in
> > Menu Maintenance to find the program in the menu. Select the
> > customization you created and save.
> > 2. Launch MES in Customization mode and load your customization of the
> > base MES screen. Open Customization mode. Find the button that launches
> > the program you want to modify and click on it. You'll need to note copy
> > its GUID in the Properties inspector. You will also need to clear the
> > EpiBinding property, as this points to the method in the underlying base
> > code that gets called when you click on the button.
> > 3. You'll need to add some custom code to the Script Editor. This needs
> > to go in the main body of the script before the End Module statement.
> > Private WithEvents btnLaunchCustomJobTracker As EpiButton
> > Private Sub MESMenu_Load(ByVal sender As object, ByVal args As
> > EventArgs) Handles MESMenu.Load
> > '// Add Event Handler Code
> > btnLaunchCustomJobTracker =
> > CType(csm.GetNativeControlReference("a8c9c646-0ee6-4428-8692-ea690de3f93
> > 3"), EpiButton)
> > End Sub
> > Private Sub btnLaunchCustomJobTracker_Click (ByVal Sender As Object,
> > ByVal args As EventArgs ) Handles btnLaunchCustomJobTracker.Click
> > ProcessCaller.LaunchForm(MESMenu, "UDPMJT01")
> > End Sub
> > Basically you're doing three things:
> > A. Creating a subroutine/method (e.g btnLaunchCustomJobTracker_Click)
> > that calls LaunchForm() with the Sub Process ID of the non-menu item you
> > created. This invokes the non-menu Sub Process item.
> > B. Adding a EpiButton object to the code that you can manipulate (vs.
> > the base code one which you can't) with your own events associated with
> > the button on the form.
> > C. Adding an event handler for that EpiButton for the Click event.
> > [I think I'm being correct with the above...someone correct me if I'm
> > wrong!]
> > You have to remove the EpiBinding property on the MES form otherwise
> > *both* your custom code and the base code action will get called. One
> > side-effect of this is that you won't get the nice enabled/disabled
> > management that MES gives you based on your configured MES privs and
> > signin/clockin status. That's handled behind the scenes by the routines
> > that get called based on that EpiBinding property. I'm not sure if
> > there's a way to get 'wired in' to this behavior or not with your custom
> > actions. Anyone?
> > You can run Tools->Test Code from the Script Editor to make sure your
> > custom VBScript actually compiles in .NET.
> > If you've done all of this correctly and I haven't forgotten something,
> > you should be able to launch your MES screen in non-developer mode,
> > click on your re-targeted button, and get your customized version of the
> > screen.
> > You can add a call to MsgBox (e.g. MsgBox("foo") ) in your _Click
> > routine to verify you're actually getting into your custom _Click
> > handler if you're having trouble. This will at least verify you're
> > getting that far.
> > Hope this helps,
> > -bws
> > Picometrix
> photonix.com
> > Behalf Of Charlie Wilson
> > We moved some fields around on the end activity screen now we want all
> > users
> > to see this new version.
> > ~Charlie
> > _____
> > Behalf Of
> > Brian W. Spolarich
> > Sent: Monday, March 30, 2009 4:17 PM
> > Charlie, what is it you want to change?
> > You can for example pretty easily point a given button at a different
> > program, or a customized version of that program. There are couple of
> > non-obvious tricks but before I spend the time writing that out I want
> > to
> > make sure I understand what you're trying to accomplish. :-)
> > -bws
> > Picometrix
> > photonix.com ~ 734-864-5618 ~ www.advancedphotonix.com
> > Sent: Monday, March 30, 2009 4:03 PM
> > What if we want to make customizations to a specific app that is on the
> > MES
> > screen such as end activity?
> > ~Charlie
> > _____
> > Behalf Of
> > Rob Bucek
> > Sent: Monday, March 30, 2009 10:22 AM
> > Sorry Charlie, I accidentally grabbed the wrong one.
> > PROBLEM:
> > How do you customize the main MES Menu and set to use it instead of
> > default?
> > SOLUTION:
> > 1. Right-click on the shortcut for Vantage 8.0 MES.
> > 2. Copy and paste the copy to the desktop.
> > 3. Rename the copy to something like MES Developer.
> > 4. Right-Click and choose Properties.
> > 5. In the Target area, locate where it shows -MES and change it to
> > -MESC.
> > 6. Click OK to save the changes.
> > 7. Login to MES Developer.
> > 8. Make your customizations and choose Save as
> > 9. Give your customization a name (i.e CustomMES)
> > 10. Save and close MES
> > 11. Log into a your a regular 8.0 session
> > 12. Go to System Management >> Utilites >> Sub Process Maintenance
> > 13. Create a new menu ID and give it a name e.g UDMES1
> > 14. Choose the security you want to apply to this option
> > 15. Enter a parent process like PROCESS or MAINMENU
> > 16. Enter a unique number for the sequence like 10, 15, 20, etc.
> > 17. Under the Program section browse to or type in
> > Epicor.Mfg.Menu.Mes.dll
> > 18. Choose the Customization name you saved in steps 4/5 from the list
> > box
> > 19. Save and close Sub Process Maintenance
> > 20. Create a Process Calling using System Management >> Utilities >>
> > Process Calling Maintenance
> > 21. Choose File >> New
> > 22. Process Called Reference = Epicor.Mfg.Menu.MES
> > 23. Menu ID = UDMES1 (Menu ID create in step 13)
> > 24. Save and close Process Calling Maintenance
> > 25. Add the process ID you just created in step # 13 as the value for
> > the MESCustomMenuID node in the xxx.mfgsys file being referenced by your
> > MES icon
> > <MESCustomMenuID value="UDMES1" /> This should be listed under the
> > <appSettings> </appsettings> section. If the icon does not reference
> > mfgsys use the default.mfgsys found the ...epicor/client/config
> > directory.
> > 26. Log into 8.0 MES again and you should now see your customization.
> > Note 1: When first installed you will need to change the xxx.mfgsys file
> > used by each MES user. You'll find this file in the config directory of
> > the epicor client folder e.g. c:\epicor\mfgsys803\client\config
> > Note 2: In a standard implementation of Vantage the name of the file
> > being changed is default.mfgsys. HOWEVER, this can change based on your
> > installation of Vantage. For example if you are running against a test
> > or pilot database the file maybe named test.mfgsys or pilot.mfgsys. You
> > may want to check the port number of the appserver that MES is using
> > agains the AppServerURL value="AppServerDC: <AppServerDC:
> > <AppServerDC: <AppServerDC: <AppServerDC://LAPIZ:8301> //LAPIZ:8301>
> //LAPIZ:8301 <AppServerDC:
> > <AppServerDC: <AppServerDC://LAPIZ:8301> //LAPIZ:8301> //LAPIZ:8301> <
> > <AppServerDC: <AppServerDC://LAPIZ:8301> //LAPIZ:8301> //LAPIZ:8301> > >
> //LAPIZ:8301>
> > //LAPIZ:8301" statement in
> > the default.mfgsys.
> > Note 3: Be sure to change the one in the Vantage client config directory
> > stored on the server. This way when you install a new release of Vantage
> > and the client folders are updated the modified xxx.mfgsys is
> > downloaded.
> > Rob Bucek
> > FAX: 715-284-4084
> <http://www.dsmfg.
> > <http://www.dsmfg. <http://www.dsmfg.com/> com/> com/> > > com/> com/>
> > Behalf
> > Of Rob Bucek
> > Sent: Monday, March 30, 2009 9:13 AM
> > I found this to be helpful for the main screen. Also do a search in
> > Vantage help for customizing any of the sub screens use 'mes
> > customization' as your search string. The instructions there aren't too
> > bad and you should be able to follow them to completion.
> > CUST How do you customize the main MES Menu and set to use it instead of
> > default
> > Details:
> > Summary: CUST How do you customize the main MES Menu and set to use it
> > instead of default
> > Book: Support Solutions
> > Page: 4306MPS
> > PROBLEM:
> > default?
> > Note: this answerbooks also worked for 8.03 MES
> > SOLUTION
> > Create your customization
> > -MESC.
> > To deploy create a SubProcess record
> > 11. Log into your a regular 8.0 session
> > box
> > Create a Calling Process Record:
> > Update the configuration file with the name of the custom MES menu.
> > the MESCustomMenuID node in the configuration file being referenced by
> > your MES icon. To find the name of your configuration file check the
> > properties of your MES icon. In the following example the
> > configuration file is named ""mes.mfgsys"".
> > C:\Epicor\vega403\client\MfgSys.exe -MES /config=mes.mfgsys
> > If the icon properties are C:\Epicor\vega403\client\MfgSys.exe -MES then
> > the the configuration file would be ""default.mfgsys"".
> > In Vantage 8.03 you can use the ConfigEditor.exe to change the value of
> > MESCustomMenuId. In this example you would set it to be
> > ""UDMES1"". In older versions of Vantage you need to open the appropiate
> > configuration file using NotePad and under the
> > <appSettings> </appsettings> section make the following change
> > <MESCustomMenuID value=""UDMES1"" /> . You'll find the configuration
> > file in the ...epicor/client/config directory.
> > 26. Log into MES again and you should now see your customization.
> > file used by each MES user.
> > Note 2: Be sure to change the one in the Vantage client stored on the
> > server so that when you install a new release of Vantage and the
> > client folders are updated the modified xxx.mfgsys is downloaded to
> > the clients.
> > -Update the server's xxx.mfgsys to the Client's.
> > Rob Bucek
> > FAX: 715-284-4084
> <http://www.dsmfg.
> > <http://www.dsmfg.
> <http://www.dsmfg.
> > com/> com/> >
> > Behalf
> > Of Charlie Wilson
> > Sent: Monday, March 30, 2009 9:05 AM
> > Subject: [Vantage] MES Customization
> > All,
> > We have a Customization we would like to deploy to our MES terminals how
> > do
> > we go about doing this?
> > ~Charlie
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > Crystal Reports and other 'goodies', please goto: http://groups.
> > <http://groups. <http://groups.
> <http://groups.yahoo.com/group/vantage/files/>
> > yahoo.com/group/vantage/files/> > >
> > yahoo.com/group/vantage/files/.
> > (2) To search through old msg's goto: http://groups.
> <http://groups.yahoo.com/group/vantage/messages>
> > yahoo.com/group/vantage/messages> > >
> > (3) To view links to Vendors that provide Vantage services goto:
> > <http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
> > yahoo.com/group/vantage/linksYahoo> > >
> > yahoo.com/group/vantage/linksYahoo! Groups Links
> > have already linked your email address to a yahoo id to enable access. )
> > and Crystal Reports and other 'goodies', please goto:
> > yahoo.com/group/vantage/linksYahoo> > ! Groups Links
> > yahoo.com/group/vantage/linksYahoo> ! Groups Links
Give me a call Charlie, perhaps I can help walk through it...
Rob Bucek
FAX: 715-284-4084
Of Charlie Wilson
Sent: Tuesday, March 31, 2009 9:22 AM
Rob,
I'm not having much luck with this process. It doesn't seem to be seeing
the
menu id when I try to open it via MESC.
~Charlie
_____
Behalf Of
Rob Bucek
Sent: Tuesday, March 31, 2009 9:59 AM
The customization should show up at each terminal or instance as you
restart them. So yes, once you restart the one you're working with it
should show up on that instance. All our MES customizations are global,
so we don't have any modifications to buttons or scripting involved in
getting these to work. Because we also have the main screen customized
as well we did have to make a reference in the config.sys file to the
sub process ID, but if youre not doing the main screen this shouldn't be
necessary. I can run a standard session of MES (with no reference) and
while the customization for the main screen will not show the sub
processes (like start and end activities) will show.
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg.com/ <http://www.dsmfg.com/> >
com/>
Behalf
Of Charlie Wilson
Sent: Tuesday, March 31, 2009 8:39 AM
Rob,
You say to restart MES.
Do I need to restart all instances of MES to make the cust. Show up or
just
the one I'm working with?
~Charlie
_____
Behalf Of
Rob Bucek
Sent: Monday, March 30, 2009 4:27 PM
First, go into sub process maintenance found under system
management/utilities.
Create a new process id (UD<name>)
Assign security
Programtype (non menu item)
Program (find the .dll corresponding to the form, in your case -
Epicor.Mfg.UI.EndActivityEntry.dll)
Assign the customization you created (from the drop down)
Go into the process calling maintenance found under system
Create new
Called process reference is the .dll you assigned under sub process
without the file extension ex. (Epicor.Mfg.UI.EndActivityEntry.dll)
Called from (the menu that calls the customized process ex.
(Epicor.Mfg.Menu.Mes)
And finally the custom menu ID you created in the sub process (UD<name>)
Restart your Epicor/mes session and you should see your customization.
Any questions call. There probably isn't one form left in the MES that
we haven't hacked
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg.com/ <http://www.dsmfg.com/> > com/
<http://www.dsmfg
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > com/> >
Behalf
Of Charlie Wilson
Sent: Monday, March 30, 2009 3:03 PM
MES
~Charlie
_____
Behalf Of
Rob Bucek
PROBLEM:
default?
SOLUTION:
-MESC.
box
MES icon
directory.
<AppServerDC://LAPIZ:8301 <AppServerDC://LAPIZ:8301> > //LAPIZ:8301
<AppServerDC: <AppServerDC://LAPIZ:8301 <AppServerDC://LAPIZ:8301> >
//LAPIZ:8301>
<AppServerDC://LAPIZ:8301 <AppServerDC://LAPIZ:8301> > //LAPIZ:8301> > >
the default.mfgsys.
downloaded.
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg <http://www.dsmfg.com/
com/> <
<http://www.dsmfg
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > com/> > >
com/>
Behalf
Of Rob Bucek
default
Details:
instead of default
Page: 4306MPS
PROBLEM:
default?
SOLUTION
-MESC.
box
the clients.
Rob Bucek
FAX: 715-284-4084
com/> <
<http://www.dsmfg
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > com/> > > com/
<http://www.dsmfg
<http://www.dsmfg
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > com/> <
com/
com/> > > com/> >
Behalf
Of Charlie Wilson
All,
do
~Charlie
I had .dll on the end of the Called process reference so that was throwing
it off thanks for all the help!
~Charlie
_____
Rob Bucek
Sent: Tuesday, March 31, 2009 10:26 AM
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg.com/> com/>
Behalf
Of Charlie Wilson
Rob,
the
~Charlie
_____
Behalf Of
Rob Bucek
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg <http://www.dsmfg.com/> com/
<http://www.dsmfg <http://www.dsmfg.com/> com/> >
com/>
Behalf
Of Charlie Wilson
Rob,
just
~Charlie
_____
Behalf Of
Rob Bucek
Assign security
Create new
we haven't hacked
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg <http://www.dsmfg.com/> com/> > com/
<http://www.dsmfg
<http://www.dsmfg <http://www.dsmfg.com/> com/ <http://www.dsmfg
<http://www.dsmfg.com/> com/> > com/> >
Behalf
Of Charlie Wilson
MES
~Charlie
_____
Behalf Of
Rob Bucek
PROBLEM:
default?
SOLUTION:
-MESC.
box
MES icon
directory.
<AppServerDC: <AppServerDC://LAPIZ:8301> //LAPIZ:8301 <AppServerDC:
<AppServerDC://LAPIZ:8301> //LAPIZ:8301> > //LAPIZ:8301
<AppServerDC: <AppServerDC://LAPIZ:8301> //LAPIZ:8301> >
//LAPIZ:8301>
<AppServerDC://LAPIZ:8301> //LAPIZ:8301> > //LAPIZ:8301> > >
the default.mfgsys.
downloaded.
Rob Bucek
FAX: 715-284-4084
com/> <
<http://www.dsmfg
<http://www.dsmfg.com/> com/> > com/> > >
com/>
Behalf
Of Rob Bucek
default
Details:
instead of default
Page: 4306MPS
PROBLEM:
default?
SOLUTION
-MESC.
box
the clients.
Rob Bucek
FAX: 715-284-4084
com/> <
<http://www.dsmfg
<http://www.dsmfg.com/> com/> > com/> > > com/
<http://www.dsmfg
<http://www.dsmfg
<http://www.dsmfg.com/> com/> > com/> <
com/
com/> > > com/> >
Behalf
Of Charlie Wilson
All,
do
~Charlie
I'm trying to customize an MES form (8.03.409)but many changes do not seem to stick - i.e., I delete a button or hide a button and it is back when I reopen the customization. Other changes do stick.
Is there some initializing code that creates objects on start-up or something perhaps you could suggest that I am failing to do that causes this?
Any documentation anyone can recommend?
It's buggy, believe it or not, the best way to work around this is to set
the size to 0,0.
Gerry Loranger
Systems Administrator
Preformed Line Products
1711 Bishop St. East
Cambridge, ON N1T 1N5
519-740-6666 Ext. 224
Email: <mailto:gloranger@...> gloranger@...
Visit our website at <http://www.preformed.on.ca> www.preformed.on.ca
If you're not in developer mode you need to add an entry in the Sub
Process Maintenance and also in the Process Calling Maintenance (both in
System management -> Utilities).
If you've made a change to the base MES menu (where you log in to) you
need to make a change to the pf file.
I'm sending you a word document off-line with more detailed
instructions.
Of CarlH
Sent: Friday, April 30, 2010 1:46 PM
this?
Or hide it behind a group box
Of Gerry Loranger
Sent: Friday, April 30, 2010 2:01 PM
set
the size to 0,0.
Gerry Loranger
<mailto:gloranger%40preformed.on.ca> > gloranger@...
Carl,
If you try to hide one of the standard buttons that were there but
blank, it will always come back on the reopening of the program. What I
finally did was put my custom buttons over the top of the standard
buttons. You should have no issues with the buttons that you create.
Tim Dines
Information Technology
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
Direct: 765-675-5201
Cell: 765-437-1402
Of CarlH
this?
If you are using Windows XP for your MES terminals, it helps to switch the desktop appearance from Windows XP style to Windows Classic style (you know with the blocky buttons and all). I used to have trouble with my personalizations and customizations not sticking (or partially sticking) until I tried it on an old PC with Visual effects set to "adjust for best performance" and it worked fine.
HTH
Plamen
Art Display Co.
I am trying to implement a change to the End Activity Screen. I cannot get to that screen through Menu Maintenance, I can only go as deep as Office MES.
Rich Wagner
[cid:image001.jpg@...50B670]
2148 Century Drive
Jefferson Hills, PA 15025
Phone: (412) 384-3100 x159
Fax: (412) 384-2033
www.bawplastics.com<http://www.bawplastics.com>
Rich,
You need to go into MES in developer mode. Modify the properties of the
shortcut you use to run MES, and add a "C" on the option "-MES", so your
link will look something like:
"C:\...\Client\MfgSys.exe" -MESC /config=dbname.mfgsys
That gets you into developer mode. Once you have your customization, you'll
need to create a record in subprocess maint, plus calling process maint.
HTH.
Kevin
RICH WAGNER
Sent: Thursday, May 13, 2010 12:06 PM
MES.
Rich Wagner
<mailto:image001.jpg%4001CAF294.AD50B670> ]
2148 Century Drive
Fax: (412) 384-2033
if possible to customization the MES Screen, if yes, HOW ?
thanks
Vantage 8.03.408b
Copy the shortcut. Go into properties of the new shortcut and change the
"MES" to "MESC".
Run the shortcut and you are in customization mode as you'd normally
see.
Right-click on form and you'll now see a customization option.
Of VantageUser13
Sent: Wednesday, June 23, 2010 10:54 AM
thanks
Vantage 8.03.408b
Once you customize you'll then need to go into the Process Calling
Maintenance and Sub Process Maintenance to set up the "menu entries" for
your customizations. If you modify the MES Menu page you need to go into
the config file as well and change it to point to your "menu item" that
you set up in the process calling maintenance.
Of Sean McDaniel
Sent: Wednesday, June 23, 2010 11:00 AM
"MES" to "MESC".
see.
Behalf
Of VantageUser13
thanks
Vantage 8.03.408b
There are detailed articles in EpicWeb on this. You'll need them.
Of Sean McDaniel
Sent: Wednesday, June 23, 2010 11:22 AM
Of Sean McDaniel
"MES" to "MESC".
see.
Behalf
Of VantageUser13
thanks
Vantage 8.03.408b
http://f1.grp.yahoofs.com/v1/cCEiTIx2siovOK4xLbJ8Kj3-HWii4cSAe4wc--PhLay
8gukz8KKfd5rnKT3cYkJ-ywfQaBD7D9L5C-wm6j9t6iLzGcuNHuGQvnabh4_D/MES_App_cu
stom.pdf
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of VantageUser13
thanks
Vantage 8.03.408b
Thanks for this guide.
> stom.pdf
> Tim Dines
> ERP Analyst
> 801 Berryman Pike
> Tipton, IN 46072
> 765-675-5201
> Of VantageUser13
> thanks
> Vantage 8.03.408b
You can modify the MES screen, it is quite involved, attached are some
instructions.
Good Luck
Regards
Andrew Marshall
IT Manager
Premier Hytemp Ltd
> thanks
> Vantage 8.03.408b
I will need on the MES, to hide a button. I go on my customization, and on load form i write this line : btnStartActivitySetup.visible = false but doesn't work. I have all the time the error message. If possible in the customization to hide the button ?
Vantage 8.03.408b
Don't "hide" the buttons.
Set the size to 0,0 and they will disappear then.
Of VantageUser13
Sent: Monday, July 12, 2010 2:25 PM
Vantage 8.03.408b
