I have a customization that I have tested and verified that it works in the MES dev environment. When I go to move it to our Pilot environment the customization does not work.
I have verified:
There is a process in the process calling maintenance for it.
The customization shows up in the process tree and I can select it
The process it is calling in dev is where i put the customization in the menu
In the forums I have been reading there is some talk of having to update the sysconfig. Do I still need to do that even though it is version 2021.1.13?
It is just the EndActivity. Is there another menu that I need to apply the customization too besides this one? Sorry if it seems like a silly question.
Thanks! That was it. That and I had to revert back to the classic view for the code to work it does not work in the Kinetic view. So instead of app=mes I had to use -mes.
Looks like a rewrite in my future. Thank you again for all of your help.
