MES Customization Question
We are going live with Epicor 9.04.506B in 2 weeks. We have a couple of issues that we'd like to customize in MES:
1. Don't allow the user to clock onto an op if the previous isn't started. (Warning in the system already)
2. Don't allow clocking if the operation isn't complete. (also a warning)
3. Don't allow the user to report more than the original job is for.
I see lots of examples of people doing this in the user groups, but I've spent hours trying to implement some of your suggestions to no avail. I've played around with BPMs and customizations, but I simply can't get anything to work.
Could someone lend a kind helping hand? I just can't seem to be able to figure this out.
I want to put a button on the MES form that will refresh the user's
production grid. I put the following code in the button's Click event
Private Sub btnRefreshGrid_Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles btnRefreshGrid.Click
'// ** Place Event Handling Code Here **
'MESMenu.MainPanel1.TaskDockPanel1.ProductionPanel1.grdLaborDetails.Refresh()
End Sub
However, this errors out, telling me
Error: BC30390 - line 65 (127) -
'Epicor.Mfg.Menu.Mes.MESMenu.mainPanel1' is not accessible in this
context because it is 'Private'.
I tried just using grdLaborDetails.Refresh() and it told me that
grdLaborDetails was not recognized. Does anyone have any
ideas/pointers? Is support helpful on these kind of customization
questions?
RussN
I should clarify that this is V8.
I also have tried the following, which compiled, but did nothing to
refresh the grid.
Dim edvLaborDtl as EpiDataView =
CType(oTrans.EpiDataViews("LaborDtl"), EpiDataView)
edvLaborDtl.Notify(new EpiNotifyArgs(MESMenu, edvLaborDtl.Row,
edvLaborDtl.Column))
RussN
> End Sub
> questions?
> RussN
In .net, usually (it may differ with that control - havent it)
refresh methods simply 'repaint' the control, rather than update the
data. In this case you may need to have a way to call into the method
that actually does the databinding, unless they provide the method
just for that purpose.
If they don't provide a way to get access to the control, there are
always 'unsupported' methods via reflection to gain access to them.
hmm...I'll have to look at this control further. One thing you can do
is use the program Reflector
http://www.aisto.com/roeder/dotnet/
to look at the methods and see what they do. One of the greatest
programs ever written : )
> refresh the grid.
edvLaborDtl.Row,
> RussN
user's
event
ByVal Args
Refresh()
resh()
> > End Sub
> > I tried just using grdLaborDetails.Refresh() and ict told me that
> > questions?
> > RussN
Thanks, Adam, that Reflector is really handy, and I think I am calling
the correct methods now.
However, I'm still getting an error. The line
call grdLaborDetails.Rows.Refresh(2)
generates the error
Error: BC30451 - line 70 (132) - Name 'grdLaborDetails' is not declared.
Does anyone know if support is helpful on customization questions? I
hate calling only to be frustrated by people who don't know much more
than I do.
RussN
> > refresh the grid.
> edvLaborDtl.Row,
> > RussN
> user's
> event
> ByVal Args
> Refresh()
> resh()
> > > End Sub
> > > questions?
> > > RussN
AFAIK you can't directly make any calls to the base form controls.
You can declare a control, even call it the same name as the base
control and then have that control mirror the base control by calling
the csm.GetNativeControlReference method
Do a search in help and they show you a basic example.
HTH
Bernie.
calling
> generates the error
declared.
I
more
> than I do.
> RussN
the
method
method
are
them.
can do
nothing to
> > > refresh the grid.
> > edvLaborDtl.Row,
> > > RussN
> > user's
Click
> > event
Object,
> > ByVal Args
> > Refresh()
> > resh()
> > > > End Sub
this
that
customization
> > > > questions?
> > > > RussN
Try looking at its EpiGuid in the properties and then you call
(for example)
Dim txt As EpiTextBox = CType(csm.getNativeControlReference
("guidHere"), EpiTextBox)
in the case of the grid, get a reference to it using its guid and
cast (ctype) it to its proper type.
calling
> generates the error
declared.
I
more
> than I do.
> RussN
the
method
method
are
them.
can do
nothing to
> > > refresh the grid.
> > edvLaborDtl.Row,
> > > RussN
> > user's
Click
> > event
Object,
> > ByVal Args
> > Refresh()
> > resh()
> > > > End Sub
this
that
customization
> > > > questions?
> > > > RussN
Good afternoon,
We are looking for a way to customize the MES End Labor Activity. Our
quality department wants a way to track which employees are being
trained.
Right now this information is entered in the comments field on the End
Activity field (the view is called end - which ties to the laborDtl
table). I am hoping that we can add a dropdown that they can pick the
trainees name and then pull that information into the laborDtl table.
As of yet we cannot figure this out - we are on 8.03.405 on Progress.
Thanks in advance for any ideas.
Brian
Well, start by making a copy of your existing MES icon/shortcut.
Change the target to this: C:\client803\client\MfgSys.exe -MESC
Add the "C" at the end to invoke the ability to perform customizations. Once MES is open, right-click on any blank area on the screen and select Customize. Perform the customizations with the same toolbox and customization methods as you would in the normal UI.
Search for Answerbook # 5213MPS on EpicWeb for instructions on how to implement your MES Customizations. It's not as easy or straightforward as the normal UI. This is for 8.x version.
Here's a copy:
AnswerBook #: 5213MPS Product: Vantage
Added:
Changed: 04/07/2008 Module: MES
07/06/2005 Version: 8.00.800
Details:
Summary:
CUST How do you customize the main MES Menu and set to use it instead of default
PROBLEM:
How do you customize the main MES Menu and set to use it instead of default?
SOLUTION:
1. Right-click on the shortcut for Vantage 8.0 MES.
2. Copy and paste the copy to the desktop.
3. Rename the copy to something like MES Developer.
4. Right-Click and choose Properties.
5. In the Target area, locate where it shows -MES and change it to -MESC.
6. Click OK to save the changes.
7. Login to MES Developer.
8. Make your customizations and choose Save as
9. Give your customization a name (i.e CustomMES)
10. Save and close MES
11. Log into a your a regular 8.0 session
12. Go to System Management >> Utilites >> Sub Process Maintenance
13. Create a new menu ID and give it a name e.g UDMES1
14. Choose the security you want to apply to this option
15. Enter a parent process like PROCESS or MAINMENU
16. Enter a unique number for the sequence like 10, 15, 20, etc.
17. Under the Program section browse to or type in Epicor.Mfg.Menu.Mes.dll
18. Choose the Customization name you saved in steps 4/5 from the list box
19. Save and close Sub Process Maintenance
20. Create a Process Calling using System Management >> Utilities >> Process Calling Maintenance
21. Choose File >> New
22. Process Called Reference = Epicor.Mfg.Menu.MES
23. Menu ID = UDMES1 (Menu ID create in step 13)
24. Save and close Process Calling Maintenance
25. Add the process ID you just created in step # 13 as the value for the MESCustomMenuID node in the
xxx.mfgsys file being referenced by your MES icon
<MESCustomMenuID value="UDMES1" /> This should be listed under the <appSettings>
</appsettings> section. If the icon does not reference mfgsys use the default.mfgsys found
the ...epicor/client/config directory.
26. Log into 8.0 MES again and you should now see your customization.
Note 1: When first installed you will need to change the xxx.mfgsys file used by each MES user. You'll find
this file in the config directory of the epicor client folder e.g. c:\epicor\mfgsys803\client\config
Note 2: In a standard implementation of Vantage the name of the file being changed is default.mfgsys.
HOWEVER, this can change based on your installation of Vantage. For example if you are running against a
test or pilot database the file maybe named test.mfgsys or pilot.mfgsys. You may want to check the port
number of the appserver that MES is using agains the AppServerURL value="AppServerDC://LAPIZ:8301"
statement in the default.mfgsys.
Note 3: Be sure to change the one in the Vantage client config directory stored on the server. This way
when you install a new release of Vantage and the client folders are updated the modified xxx.mfgsys is
downloaded.
From: vantage@yahoogroups.com on behalf of bdmang_83
Sent: Wed 6/25/2008 7:00 PM
Subject: [Vantage] MES Customization Question
Good afternoon,
trained.
Brian
Thanks Vic,
We can customize our MES - the main problem is we want to add a
field to the End Activity screen (which we have done) and get that
information to the laborDtl Table. The End Activity screen is a view
called "end" and from what I can tell when the "ok" button is clicked
a function is run that inserts the comments and links them to that
particular record.
Any suggestions on how to do this are appreciated.
Brian
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
> Here's a copy:
> Added:
> Details:
> Summary:
instead of default
> PROBLEM:
default?
> SOLUTION:
MESC.
list box
<appSettings>
customization.
> downloaded.
> Good afternoon,
Our
> trained.
End
the
table.
Progress.
> Brian
The user fields in the End view are the user fields in the LaberDtl
table. You just ahve to add the fields to the form and link them to
whatever fields you want to use. I have added 16 fields to the End
Activity form
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of bdmang_83
Sent: Thursday, June 26, 2008 9:03 AM
Subject: [Vantage] Re: MES Customization Question
Thanks Vic,
particular record.
Brian
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
> Here's a copy:
> Added:
> Details:
> Summary:
instead of default
> PROBLEM:
default?
> SOLUTION:
MESC.
list box
<appSettings>
customization.
value="AppServerDC://LAPIZ:8301 <AppServerDC://LAPIZ:8301> "
> downloaded.
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
behalf of bdmang_83
> Good afternoon,
Our
> trained.
End
the
table.
Progress.
> Brian
Kersten,
Did you need to add a FKV to the End Activity Form? One other
question - are you able to pull information from your custom fields
into reports?
Brian
--- In vantage@yahoogroups.com, "Kersten MacLennan" <kmaclennan@...>
> Activity form
> Kersten MacLennan
> IT/ERP Analyst
> Semrock, Inc.
> 3625 Buffalo Rd.,
> Suite 6
> Rochester, NY 14624
> 585-594-7009
> 585-594-7095 fax
> kmaclennan@...
Instrumentation
reader
responsible
hereby
you
delete
> it. Thank you
Behalf
> Of bdmang_83
> Thanks Vic,
view
clicked
> particular record.
> Brian
> Drecchio" <vic.drecchio@>
the
UI.
how
> > Here's a copy:
> > Added:
> > Details:
> > Summary:
> instead of default
> > PROBLEM:
of
> default?
> > SOLUTION:
to -
> MESC.
Maintenance
> list box
the
> <appSettings>
> customization.
xxx.mfgsys
e.g.
For
> > downloaded.
on
> behalf of bdmang_83
> > Good afternoon,
> Our
> > trained.
the
> End
laborDtl
> the
> table.
> Progress.
> > Brian
No FKV is required for what you need. The data views are already
present.
And, regarding reports, of course. It's easy to make BAQ reports that
hit your custom data.
Of bdmang_83
Sent: Thursday, June 26, 2008 9:30 AM
Kersten,
into reports?
Brian
> Activity form
> Kersten MacLennan
> IT/ERP Analyst
> Semrock, Inc.
> 3625 Buffalo Rd.,
> Suite 6
> Rochester, NY 14624
> 585-594-7009
> 585-594-7095 fax
> kmaclennan@...
Instrumentation
reader
responsible
hereby
you
delete
> it. Thank you
Behalf
> Of bdmang_83
> Thanks Vic,
view
clicked
> particular record.
> Brian
<mailto:vantage%
the
UI.
how
> > Here's a copy:
> > Added:
> > Details:
> > Summary:
> instead of default
> > PROBLEM:
of
> default?
> > SOLUTION:
to -
> MESC.
Maintenance
> list box
the
> <appSettings>
> customization.
xxx.mfgsys
e.g.
For
<AppServerDC://LAPIZ:8301 <AppServerDC://LAPIZ:8301> > "
> > downloaded.
on
> behalf of bdmang_83
> > Good afternoon,
> Our
> > trained.
the
> End
laborDtl
> the
> table.
> Progress.
> > Brian
No I did not have to add any foreign key views and I run reports on the
additioanl data all of the time. I have however maintained a document to
keep track of all of the user fields in use since you can't rename them.
The only FKV I have used is to grab the production quantity from the
JobHead table. Keep in mind that the user fields in start activity are
the same as end activity so if you are customizing both forms don't use
the same fields.
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of bdmang_83
Kersten,
into reports?
Brian
> Activity form
> Kersten MacLennan
> IT/ERP Analyst
> Semrock, Inc.
> 3625 Buffalo Rd.,
> Suite 6
> Rochester, NY 14624
> 585-594-7009
> 585-594-7095 fax
> kmaclennan@...
Instrumentation
reader
responsible
hereby
you
delete
> it. Thank you
Behalf
> Of bdmang_83
> Thanks Vic,
view
clicked
> particular record.
> Brian
<mailto:vantage%
the
UI.
how
> > Here's a copy:
> > Added:
> > Details:
> > Summary:
> instead of default
> > PROBLEM:
of
> default?
> > SOLUTION:
to -
> MESC.
Maintenance
> list box
the
> <appSettings>
> customization.
xxx.mfgsys
e.g.
For
> > downloaded.
on
> behalf of bdmang_83
> > Good afternoon,
> Our
> > trained.
the
> End
laborDtl
> the
> table.
> Progress.
> > Brian
