Thanks Brian.
Another question if I may. I want the filter code to run whenever the user clicks the Current Work, Available Work or the Expected Work. I'm guessing I should use the Form Event Wizard, but not sure what would be the best Event Type?
Any suggestions?
Any suggestions?
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Start Epicor with the /MESC flag, then right click on the background of
> the MES screen to start customization. At that point you've got the
> regular tools available.
> Once your customization is complete & ready to deploy, you'll need to
> add a new menu item in Menu Maintenance, pointing to
> Epicor.Mfg.Menu.Mes.dll and select your customization. Then modify the
> client default.mfgsys, and look for the MESCustomMenuID line, and put
> that menu item there. Then people starting MES will get your
> customization loaded by default.
> Brian.
> Of Tim Vonderhaar
> Sent: Tuesday, June 19, 2012 1:55 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] MES Customization 9.05.700
> We would like to customize the MES environment so that it would
> automatically set the work queue current/available/expected work to
> filter by the logged in employee. Right now, we have a machinists
> resource group and when a particular machinist logs in, they see all the
> work of everyone in that resource group. To make it easy for the floor,
> we would like the list to automatically filter by that employee so they
> don't have to. Never doing an MES customization, I am at a loss on how
> to tackle this.
> Tim
