How do I get the menu maintenance to classic view or user choice. I have it set in my pilot environment but I didn’t it so long ago I can’t figure it out in my new environment. I know I struggled with this before.
This changes by version… if you’re still on 2022.2 (meaning you’re also on-premise), try this:
- Open Menu Maintenance (in Kinetic)
- navigate down to and open the Menu Maintenance entry (there are two instances of Menu Maintenance, remember which one you’re changing!)
- MAKE SURE there is a value in the “Kinetic Application” field that says “Ice.UI.MenuMEntry” AND there is a value in the “URL” field
- on the overflow menu (top right) select Kinetic Options
- there are a couple of toggles there, I don’t remember how they’re worded, but set them so that Classic is enabled and NewUI isn’t (or something like that)
- SAVE and close
- Exit Epicor entirely
When yo log back in, the Menu Maintenance instance that you changed ought to come up in Classic when clicked.
