Menu Item Search
Is there a quick way to search for an menu item in the tree view? For example, I want to know where the Shop Load report is located in the menu tree or to be able to access it through search. There are a few custom reports out there that I know the name of the report but do not know where it is located in the menu tree (i.e. Prod Mgmt>Job Mgmt>Reports)
When you search for a menu item, the path to get there is listed below it. Is that what you are looking for?
I tried that in the Search Panel but then I get an error:
“Search results not available at this time. Error Details: The underlying connection was closed: An unexpected error occurred on a receive.”
