I am trying to migrate 25k Part Memos and I can’t make it work. Sometimes when I open it, it says it needs Key1ColumnName. I use that and it validates but then every row fails with ‘Object reference not set to an instance of an object’.
I take that to mean that it wants the RelatedToSysRowID. But for a migration process, that’s pretty unreasonable, as that means I have to extract all of the SysRowIDs for the migrated parts, load them to a temporary location and map them to the Memos to build the load file, rather than the DMT making the connection via the PartNum as specified in Key1. Even though it’s kind of crazy, I tried it for a small sample and on the first try it now told me that the Key1ColumnName shouldn’t be in the file… so I dropped it.
The load then seemed to finish with no errors. But then I checked the UI and the tables and NOTHING had actually been loaded.
What am I missing? How can I load this large volume of Memos using DMT the way it’s supposed to work.
