We have a supplier that has over 2000 parts in Supplier Price List. Â I have a Part quick search that allows our purchasers to select parts based on PartPlant supplier ID. Â In this case, if they use "return all rows", then "Select all", they get the following error:
The maximum size of the input data is 32K. Â If you need more than that then please use input TEMP-TABLES. (7229)
Epicor Support told me that this is a cutoff value set in the Supplier Price List program, and that they would be happy to provide consulting services to customize the program to up the value for me. Â I can do this myself if it really can be done through a customization, and not requiring the SDK to modify. Â
Has anyone changed this value? Â Do you know where it is set?
Thanks!
Tanya Denison | IT ManagerÂ
NRS - 100% Employee Owned
2009 S. Main Street, Moscow, IDÂ 83843
p: 208.883.7834 Ext 277 |Â c: 208.301.0599 |Â f: 208.882.1744
