Maximum database file size is 2 GB
Hi Tim,
Can I have the doument please?
--- In vantage@yahoogroups.com, Tim Care <ecfmis@e...> wrote:
> You can also talk to Vantage support about this. There is
> a Progress procedure that can be used to copy your existing
> database into one with multiple extents. They helped us
> through this same thing.
> Tim Care
> Electro Chemical Finishing
> -----Original Message-----
> From: william [mailto:william@p...]
> Sent: Friday, September 21, 2001 12:18 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Maximum database file size is 2 GB
> While I have not dealt with the issue in this context, what you
need to
> do, pronto, is reconfigure your db into more extents. Since you are
on
> vantage 5, I am assuming Progress 9.1x.
> A little background. As you have discovered, Version 9 is muti-
volume,
> and version 9.1 adds the concept of Areas. Tables and indexes may be
> assigned to areas (indexes can be in a different area than the table
> they describe), and each area is made up of one or more extents.
Extents
> may be either fixed length, (when you create the database, a file
of the
> specified size is created immediately) or variable length (a small
file
> is created initially, and it grows as you add data to it). As
noted, no
> single extent can exceed 2Gb. The data area to which a table or
index is
> assigned is not part of the CRC of the table or index, so you can
> reconfigure you Data Base with invalidating the .r files. By default
> version 9 databases are created with only a schema area. You can put
> tables in this area, but PSC strongly recommends not to do so.
Also, you
> may have only one variable extent per data area, and it must be the
last
> one in the data area.
> So to address your problem. Get hold of the Database Admin Guide and
> Reference. Available in PDF format at www.progress.com, if you can't
> find the CD. Chapter 7 contains a detailed description of the steps
> needed to restructure a data base. The basic steps are:
> - MAKE A BACKUP.
> - MAKE ANOTHER BACKUP.
> - create a file containing the details of areas/extents that you
want to
> add.
> - using the prostrct add utility apply the new structure to the data
> base .
> - if you have created new data areas, use the proutil tablemove
and/or
> indexmove utilities to move tables and indexes to their new homes.
> - test the new structure.
> - if all is well, move it into production.
> - Note that if you apply new extents to your existing db, the
current
> variable length extent will become a fixed length extent, at its
current
> size.
> The above is a very brief summary of what need to be done. There
are, of
> course, many other options available. The ones you choose will
largely
> depend on you bravery (foolhardiness?), previous experience, and
> available resources. More help is available www.peg.com. Subscribe
to
> the DBA list where the heavy hitters in this subject hang out.
> HTH.
> Chris Lantz wrote:
> > In the Pre-Installation Checklist for Vantage 5.10, at the bottom
of
> > page 11 it states
> > "The maximum size for any Progress database file (Vantage.b1,
> > Vantage.d1, or Vantage.lg) is 2 GB. If any database file
approaches
> > this limit, please contact Vantage technical support for
assistance."
> > Our Vantage.d1 file is currently 1.6 GB. Has anyone else dealt
with
> > this issue?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
> have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder and
> > (3) To view links to Vendors that provide Vantage services goto:
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Specialists in Progress Databases and Software since 1986
> William E. Colls william@p...
> PROComputer Systems Tel 613 591 0079
> 67 Willow Glen Dr. Fax 613 591 3924
> Kanata Ontario Canada www.procomsys.com
> K2M 1T1
must have
Builder and
In the Pre-Installation Checklist for Vantage 5.10, at the bottom of
page 11 it states
Vantage.d1, or Vantage.lg) is 2 GB. If any database file approaches
this limit, please contact Vantage technical support for assistance."
Our Vantage.d1 file is currently 1.6 GB. Has anyone else dealt with
this issue?
It just means that you will have to change your database to a multi volume
set. I am not looking forward to doing this on ours, but hopefully that
should be another year away. :-}
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, September 21, 2001 6:32 AM
Subject: [Vantage] Maximum database file size is 2 GB
> page 11 it states
> this issue?
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
While I have not dealt with the issue in this context, what you need to
do, pronto, is reconfigure your db into more extents. Since you are on
A little background. As you have discovered, Version 9 is muti-volume,
they describe), and each area is made up of one or more extents. Extents
may be either fixed length, (when you create the database, a file of the
specified size is created immediately) or variable length (a small file
is created initially, and it grows as you add data to it). As noted, no
single extent can exceed 2Gb. The data area to which a table or index is
tables in this area, but PSC strongly recommends not to do so. Also, you
may have only one variable extent per data area, and it must be the last
- MAKE A BACKUP.
- create a file containing the details of areas/extents that you want to
add.
base .
- if you have created new data areas, use the proutil tablemove and/or
- Note that if you apply new extents to your existing db, the current
variable length extent will become a fixed length extent, at its current
size.
The above is a very brief summary of what need to be done. There are, of
course, many other options available. The ones you choose will largely
available resources. More help is available www.peg.com. Subscribe to
HTH.
> page 11 it states
> this issue?
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
William E. Colls william@...
K2M 1T1
Tim Care
- MAKE A BACKUP.
add.
base .
size.
HTH.
> page 11 it states
> this issue?
K2M 1T1
Chris,
We went multi-volume awhile back. The one thing I remember was that Vantage
Support really knew their stuff. They even explained it so good that a bean
counter like myself could understand it. Call them on this one.
Sent: Thursday, September 20, 2001 4:03 PM
page 11 it states
this issue?
