Material ticket prints very tiny
I didn't see what version of Crystal Viewer you're using on the PC with the printing problem (if it's only 1), but I had posted quite a while back on this when we ran into it on Vantage 8.03.  We ended up rolling the PCs with the printing problem back to CR2008 SP4 (instead of SP5), also disassociated the printer/paper, used no printer and set the size to 3x2 landscape.
Material ticket prints very tiny in the upper left corner
Reinstalled crystal drivers no luck
I've seen barcodes print tiny... Simple fix...restart the computer...
Sent from my iPhone
On Nov 25, 2014, at 12:47 PM, "tracer235@... [vantage]" <vantage@yahoogroups.com> wrote:
Did that no luck
By chance was the default printer changed? Make sure the default printer in Windows is the thermal/barcode printer.
Sent: Tuesday, November 25, 2014 12:48 PM
Subject: [Vantage] Material ticket prints very tiny
Tried that no luck
Yes tried that no luck
OK, so it is just one specific type of barcode label or is it all of them? Do you have other thermal printers that are also exhibiting the same thing? This just started happening and it was fine last week?
Sent: Tuesday, November 25, 2014 1:29 PM
Subject: [Vantage] Re: Material ticket prints very tiny
Do a Print Preview.
What size of output does it show?  The same as the label you have? Or does it look like a full sheet of paper?
Change printer’s paper size or form size as needed.  Both in Preference and on the advanced tab.
Or try making label printer default printer after you are sure the paper/form size is correct for the printer.
Denton Yoder
Add user define labels to the printer printing preferences
Page Setup.
If 2x3, set is as 4x4
Id 4x6 set it as 4x10
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, November 25, 2014 11:55 AM
Do a Print Preview.
Denton Yoder
