Thank you Rob.
Sent: Monday, March 30, 2015 10:28 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] RE: Material Requirements
Then I would simply make a little dashboard that you can enter the job either in a tracker view or as a parameter and group by material part number and sum up your quantities, filter by what's already been issued and you should be good to go.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Monday, March 30, 2015 9:24 AM
Yes and No. A lot of the subassemblies are basically the same part numbers but, different quantities. We are trying to prevent the person issuing the parts from issuing 5 different parts over 50 times. Once we create the job we are combining materials on the top level.
Sent: Monday, March 30, 2015 9:57 AM
What are you looking to total them up for, purchasing demand? If so, look to your PO suggestions for that, you can also control what those suggestions look like by utilizing parameters under part/plant set up. Either way, that's a simple BAQ query/dashboard against the JobMtl table.
Rob Bucek
FAX: (715)284-4084
Sent: Monday, March 30, 2015 8:53 AM
Subject: [Vantage] Material Requirements
We are just starting to actively use MRP. If we have a job that has over 50 sub-assemblies, is there a way to total up the materials specific to that job?
Millicent
This message is intended only for the addressee and may contain information that is company confidential or privileged. Any technical data in this message may be exported only in accordance with the U.S. International Traffic in Arms Regulations (22 CFR Parts 120-130) or the Export Administration Regulations (15 CFR Parts 730-774). Unauthorized use is strictly prohibited and may be unlawful. If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message. If you have received this email in error, please delete it, and advise the sender immediately.
Rob Bucek
FAX: (715)284-4084
Rob Bucek
FAX: (715)284-4084
Millicent
