Mass update to a check box field in Customer Table
Thanks for the help. I am now pointed in the right direction.I got to BAM..I
coded my .p file to perform the necessary action and I have my newly
Created program in the alert program but I keep getting the following
exception error
Exception caught in: Epicor.Mfg.BO.ChgLogGA
Error Detail
Message: Field is not included on the ChgLogGA.UseFieldList.
Type: Error
Program: bo/ChgLogGA.p
Method: bamRuleBeforeUpdate
Table: ttBAMRule
Row:
Field: RuleField
Stack Trace
at Epicor.Mfg.Proxy.ChgLogGAImpl.Update(ChgLogGADataSet ds)
at Epicor.Mfg.UI.Adapters.ChgLogGAAdapter.Update()
at Epicor.Mfg.UI.App.ChgLogGAEntry.Transaction.Update()
How do I resolve it and how can I complete the set up?
Thanks in advance.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
_____
advantage
Sent: Monday, August 31, 2009 11:47 AM
Subject: Re: [Vantage] Mass update to a check box field in Customer Table
Yes a BPM can update based on a condition multiple rows of fields fields
within the data with a command called UpdateTableBuffer.p
i.e.
for each ttOrderHed where (ttOrderHed.RowMod = 'U' or ttOrderHed.RowMod =
'A'), each OrderRel where OrderRel.Company = ttOrderHed.Company and
Orderrel.OrderNum = ttOrderHed.OrderNum exclusive-lock.
Run lib\UpdateTableBuffer.p(input BUFFER OrderRel:HANDLE,
'FirmRelease',"NO").
End.
----- Original Message -----
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Sent: Monday, August 31, 2009 11:30 AM
Subject: [Vantage] Mass update to a check box field in Customer Table
Good morning group
Has anyone performed a mass update on a check-box field to be reflected on
all records in Epicor DB? If yes, how do I go about it?
Thanks.
Best Regards,
Herby Dallard
hdallard@ergpower. <mailto:hdallard%40ergpower.com> com
www.ergpower.com
Good morning group
Has anyone performed a mass update on a check-box field to be reflected on all records in Epicor DB? If yes, how do I go about it?
Thanks.
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
Yes a BPM can update based on a condition multiple rows of fields fields within the data with a command called UpdateTableBuffer.p
i.e.
for each ttOrderHed where (ttOrderHed.RowMod = 'U' or ttOrderHed.RowMod = 'A'), each OrderRel where OrderRel.Company = ttOrderHed.Company and Orderrel.OrderNum = ttOrderHed.OrderNum exclusive-lock.
Run lib\UpdateTableBuffer.p(input BUFFER OrderRel:HANDLE, 'FirmRelease',"NO").
End.
Good morning group
Thanks.
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
