Mass Update Tasks by Quote
I’m using a BPM invoked by User Process Scheduler. This is driving me nuts, because it worked a couple of times and now is giving me an error when I invoke
Code:
Summary
var Parameters = new Ice.Core.TaskParameterInformation(this.Db, taskNum);
    var custNum = Convert.ToInt32(Parameters.GetCharacterValue("TxtParam1"));
    var followUpDate = Convert.ToDateTime(Parameters.GetDateValue("DatParam1"));//looks misspelled but isn't
    DateTime dateValue = DateTime.Now;
    DateTime.TryParse(Parameters.GetCharacterValue("DatParam1"), out dateValue);//looks misspelled but isn't
    var followUpDate = dateValue;
    Dictionary<int, DateTime?> queue = new Dictionary<int, DateTime?>();
    foreach(var quote in (from q in Db.QuoteHed.With(LockHint.NoLock)
                        where
                          q.Company == Session.CompanyID
                          && q.CustNum == custNum
                          && q.Quoted == false
                          && q.QuoteClosed == false
                          && q.ActiveTaskID == "ACTV"
                        select new {
                          q.QuoteNum, q.FollowUpDate
                        /*Start Iteration Action*/
                          if(quote != null)
                            queue.Add(quote.QuoteNum, quote.FollowUpDate);
                        /*End Interation Action*/
    //TEST WITH SINGLE QUOTE
    //queue.Add(59689, DateTime.Today);
    if(queue.Any())
      foreach(var row in queue)
        using(Erp.Contracts.QuoteSvcContract quoteSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.QuoteSvcContract>(Db))
          //update the QuoteHed.ResponsibleFor_c and QuoteHed.Character03 to "ASC" and "COVID-19 Hold"
          //set QuoteHed.FollowUpDate to either the user input follow up date or if it has one, leave it alone.
          var quoteTS = quoteSvc.GetByID(row.Key);
          quoteTS.QuoteHed[0]["ResponsibleFor_c"] = "ASC";
          quoteTS.QuoteHed[0]["Character03"] = "COVID-19 Hold";
          quoteTS.QuoteHed[0].RowMod = "U";
          if(row.Value != null)
              quoteTS.QuoteHed[0].FollowUpDate = row.Value;
          else
              quoteTS.QuoteHed[0].FollowUpDate = followUpDate;
          quoteSvc.Update(ref quoteTS);
        //Update the task from "Active" to "Hold"
        using(Erp.Contracts.TaskSvcContract taskSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.TaskSvcContract>(Db))
            string whereClause = string.Format("Key1 = '{0}' AND RelatedToFile = 'QuoteHed' BY TaskSeqNum DESC", row.Key.ToString());
            int pageSize = 0;
            int absolutePage = 0;
            bool morePages = false;
            var taskTS = taskSvc.GetRows(whereClause, "", pageSize, absolutePage, out morePages);
            //use the top row to get the specific task
            string relatedToFile = "QuoteHed";
            string key1 = row.Key.ToString();
            string key2 = "";
            string key3 = "";
            int taskSeqNum = taskTS.Task[0].TaskSeqNum;
            taskTS = taskSvc.GetByID(relatedToFile, key1, key2, key3, taskSeqNum);
           bool lProposedComplete = true;
           string cMessage = "";
           //prepare update
           taskTS.Task[0].Complete = true;
           taskTS.Task[0].ReasonCode = "Next";
           taskTS.Task[0].NextTaskSeq = 10;
           taskTS.Task[0].NextStage = "OPPORTUNITY";
           taskTS.Task[0].NextTaskList = "10`Hold~30`Order Complete";
           taskTS.Task[0].TaskCompletePasswordIsValid = true;
           taskTS.Task[0].RowMod = "U";
           taskSvc.ChangeComplete(ref taskTS, lProposedComplete, out cMessage);
           //prepare update
           taskSvc.Update(ref taskTS);
      queue.Clear();
It’s getting through the Quote Update on the first record, then dumping an exception in the System Monitor saying “The table ttTask has more than one record”
