Hi all, I have been asked to add the finished part number to the Mass Issue to Mfg Movement Report. I’m not really understanding how this report data definition works - usually I’m used to seeing multiple relationships listed, however this has none.
So the only thing I could think to do was to create a relationship of parent (PartTran) to child (JobHead) so I can grab the PartNum from JobHead Table.
Here is the query for the dataset PartTran I have amended:
=“SELECT T2.PartNum as FinishedPart,T2.PartDescription as FinishedPartDesc, T1.AdditionNum,T1.AsOfSeq,T1.AssemblySeq2,T1.BinNum,T1.BinNum2,T1.BinType,T1.Calc_Bin2Description,T1.Calc_BinDescription,T1.Calc_EntryPerson,T1.Calc_InvoiceDate,T1.Calc_ReasonDescription,T1.Calc_WareHouse2Desc,T1.Calc_Weight,T1.DisposalNum,T1.EntryPerson,T1.InvAdjSrc,T1.JobNum,T1.JobSeq,T1.LbrUnitCost,T1.LegalNumber,T1.LoanFlag,T1.LotNum,T1.MscNum,T1.MtlUnitCost,T1.OrderRelNum,T1.PartDescription,T1.PartNum,T1.Plant,T1.Plant2,T1.POLine,T1.PONum,T1.POReceiptQty,T1.PurPoint,T1.TranDate,T1.TranReference,T1.TranType,T1.UM,T1.WareHouseCode,T1.ActTranQty,T1.AsOfDate,T1.AssemblySeq,T1.AssetNum,T1.BurUnitCost,T1.Calc_DocNum,T1.Calc_InvoiceNum,T1.Calc_LineNum,T1.Calc_PrintedBy,T1.Calc_SNList,T1.Calc_VendorAddrList,T1.Calc_VendorID,T1.Calc_WareHouseDesc,T1.Company,T1.EmpID,T1.ExtCost,T1.InvAdjReason,T1.JobNum2,T1.JobSeq2,T1.LotNum2,T1.OrderLine,T1.OrderNum,T1.PackLine,T1.PackNum,T1.PackSlip,T1.PBInvNum,T1.PORelNum,T1.POUnitCost,T1.ProjProcessed,T1.SubUnitCost,T1.SysDate,T1.SysTime,T1.TranDocTypeID,T1.TranNum,T1.TranQty,T1.WareHouse2,T1.RptLanguageID
FROM PartTran_” + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN JobHead_" + Parameters!TableGuid.Value + " T2
ON T1.Company = T2.Company AND T1.JobNum = T2.JobNum"
Trying to create a report using this causes an error “Query execution failed for dataset ‘PartTran’. —> System.Data.SqlClient.SqlException: Incorrect syntax near the keyword ‘JOIN’.”
If I make it just a LEFT JOIN, then the error states that all T1 fields could not be bound.
Any advice please on where I might be going wrong? Thank you!
