Manual Override BPM
Or, you could put if you are a member of a security group, you can override or bypass the BPM...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Friday, March 22, 2013 8:01 AM
Subject: RE: [Vantage] Re: Manual Override BPM
That's precisely what I have done in the past. I put a checkbox on the
form. If CheckBox is enabled. then bypass the BPM.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
saberlogic_aellis
Sent: Friday, March 22, 2013 7:59 AM
Subject: [Vantage] Re: Manual Override BPM
What if you just dropped a checkbox field next to the plant on the form,
label it 'override' or 'lock' (or something like that), and then just add a
condition to the BPM that says this checkbox field is false?
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
"sanjay219@...<mailto:sanjay219@...>" <sanjay219@...<mailto:sanjay219@...>> wrote:
> hello
> i have a BPM in sales order entry that looks for OnHand Qty in a plant A,
if pant A doesnt have the full amount, it release to plant B.
> Sometimes, customer service needs to overide this BPm on special orders
that need to ship out of plant B but the part number has on hand qty in
plant A.
> the current bpm is a post-process and if i manually change the release
plant to plant b it automatically changes back to plant a. i understand is
the BPM but how can i modify my code to let me overide the BPM in sales
order entry.
> Thanks
> Sanjay
No virus found in this message.
Checked by AVG - www.avg.com<http://www.avg.com>
Version: 2012.0.2240 / Virus Database: 2641/5694 - Release Date: 03/21/13
Version: 2012.0.2240 / Virus Database: 2641/5695 - Release Date: 03/21/13
hello
i have a BPM in sales order entry that looks for OnHand Qty in a plant A, if pant A doesnt have the full amount, it release to plant B.
Sometimes, customer service needs to overide this BPm on special orders that need to ship out of plant B but the part number has on hand qty in plant A.
the current bpm is a post-process and if i manually change the release plant to plant b it automatically changes back to plant a. i understand is the BPM but how can i modify my code to let me overide the BPM in sales order entry.
Sanjay
Just put a condition on your BPM that the Plant Field Has Not Changed from
Any to Any.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Thu, Mar 21, 2013 at 4:33 PM, sanjay219@... <sanjay219@...>wrote:
> hello
> plant A.
> order entry.
> Thanks
> Sanjay
Thanks Jose,
I dont find that condition in post-processing. Just in Pre-processing.
Any other condition?
Sanjay
> Any to Any.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > hello
> > plant A.
> > order entry.
> > Thanks
> > Sanjay
You'll ahve to do the condition on PreProc but then "Enable the Post Proc
Directive" then make the condition in Post Proc be "Has been enabled from
PrePrc" sorry if th'ats confusing.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Mar 21, 2013 at 4:40 PM, sanjay219@... <sanjay219@...>wrote:
> Thanks Jose,
> Thanks
> Sanjay
> from
> > Any to Any.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > <http://www.google.com/profiles/jose.gomezhttp://www.twitter.com/joc85>
> > > hello
> A,
> > > plant A.
> understand is
> > > order entry.
> > > Thanks
> > > Sanjay
Thanks. I did all those steps, the only one that didnt match was the pre-processing. You said ' has not change from any to any'. But there is only 'has changed from any to any'. I did the test and my BPM didnt even kick off. Am i missing something?
Thanks.
Sanjay.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks Jose,
> > Thanks
> > Sanjay
> > from
> > > Any to Any.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Thu, Mar 21, 2013 at 4:33 PM, sanjay219@ <sanjay219@>wrote:
> > > > hello
> > A,
> > > > plant A.
> > understand is
> > > > order entry.
> > > > Thanks
> > > > Sanjay
Jose,
if i did this correctly, the way my BPM kicks off is on the change of the release plant correct that i would have to manually change? But what i want is the bpm to kick in and if i need to change the release then i manually change it. thanks jose
Sanjay
> Thanks.
> Sanjay.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > On Thu, Mar 21, 2013 at 4:40 PM, sanjay219@ <sanjay219@>wrote:
> > > Thanks Jose,
> > > Thanks
> > > Sanjay
> > > from
> > > > Any to Any.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > hello
> > > A,
> > > > > plant A.
> > > understand is
> > > > > order entry.
> > > > > Thanks
> > > > > Sanjay
the solution you provided works buts its the opposite of what am looking for. i need the bPM to run and then i have the ability to manually change it.
sanjay
> Jose,
> Sanjay
> > Thanks.
> > Sanjay.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Thanks Jose,
> > > > Thanks
> > > > Sanjay
> > > > from
> > > > > Any to Any.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > > hello
> > > > A,
> > > > > > plant A.
> > > > understand is
> > > > > > order entry.
> > > > > > Thanks
> > > > > > Sanjay
Just invert your logic so hmm I don't have epicor handy but I am sure there
is a way to check for hasn't changed
> Thanks.
> Sanjay.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > <http://www.linkedin.com/in/josecgomezhttp://www.facebook.com/josegomez>
> > > Thanks Jose,
> > > Thanks
> > > Sanjay
> > > from
> > > > Any to Any.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > hello
> plant
> > > A,
> orders
> qty in
> > > > > plant A.
> release
> > > understand is
> sales
> > > > > order entry.
> > > > > Thanks
> > > > > Sanjay
What if you just dropped a checkbox field next to the plant on the form, label it 'override' or 'lock' (or something like that), and then just add a condition to the BPM that says this checkbox field is false?
> hello
> Thanks
> Sanjay
saberlogic_aellis
> hello
plant A.
order entry.
> Thanks
> Sanjay
Thanks, It worked perfect. I appreciate your help.
Sanjay.
> > hello
> > Thanks
> > Sanjay
Thanks Everyone.
> > hello
> > Thanks
> > Sanjay
