Make column in grid editable
Hello,
E9.05.702A
I added a custom Grid and bound it to a dataview. I used the columns property to select which columns are visible.
One of the columns that I need to show and allow edit is CheckBox01. When I toggle the visible property, it sticks and I can see it but it a toggle the read only property, it doesn’t stick and the column is read only.
I go back into the customization and it’s checked as Read Only again. I can’t seem to override it.
How can I make this field editable in the grid?
JOE ROJAS
Epicor Applications Manager
VENTION MEDICAL + DESIGN & DEVELOPMENT
Advancing Your Innovations For Health
261 Cedar Hill Street | Marlborough, MA 01752
DIRECT: 508.597.1392 x1625 | MOBILE: 774.826.9245
EMAIL: JoRojas@ventionmedical.commailto:JoRojas@ventionmedical.com | WEB: ventionmedical.com http://www.ventionmedical.com/
THINK QUALITY. BE QUALITY. GO BEYOND.
This communication may contain information that is confidential, proprietary or exempt from disclosure, and is intended only for the use of the individual and/or entity it is addressed to. If you are not the intended recipient, please note that any other dissemination, distribution, use or copying of this communication is strictly prohibited. If you have received this message in error, please notify the sender immediately by telephone or by return e-mail, and delete this information from your computer.
Joe try setting ReadOnly=false in the EpiDataView Extended Properties
Thanks Jose.
I looked at the Object Explorer to figure out the syntax but I’m not seeing it.
If you don’t mind, what would the code look like?
JOE ROJAS
Like this
edvJobHead.dataView.Table.Columns["JobNum"].ExtendedProperties["ReadOnly"] = false;
Awesome!
Thanks Jose.
JOE ROJAS
Hi Jose,
I was able to make the field updateable using your code but what is odd is that the values are not saving.
I’m working in the Time and Material Invoice Review screen in the Project Management module.
I suspect that is has something to do with how screen and BO are identifying changes because there are a few fields that are updatable and if I check my checkbox, change one of these fields, and then save it will save the check box. However, if I just change the checkbox and save…it does not save.
I have a couple of ideas on how to get around this but I thought I would see if you, or others, might have an idea.
JOE ROJAS
