We have amended BOM and want it to be affected on the existing job that uses the BOM.
Seems like it not affect on the existing job and it is still shows the Required Qty using the old qty.
As I know, It can use the Job Entry menu to change BOM directly. Can you share the step?
Kindly advise.
aclements
(Andrew Clements)
2
Hi,
You will need to delete all the operations and resources assigned to the job and then go into the Actions menu and select ‘Job → GetDetails’.
You can then select the relevant part/revision.
Your job needs to have the ‘Engineered’ checkbox unchecked.
Cheers,
Andrew.
