On form load you could call a simple search. Just create the simple search from the customization wizard, then call the method epicor wizard creates Form_OnLoad
EDIT
Kinda misread your initial post a little bit I think. You want to open a tracker/entry screen will all open orders populated eh? This post is more tuned in for like a default form value sorry!
@Asz0ka Right, but on the plus side, I rather enjoyed reading that post! The barcoding/MES sub-thread was really interesting since we are exploring that right now.
@Evan_Purdy That’s probably over my head. I just thought I had read about this in an Epicor doc as something built in to the system. Maybe I’m imagining it.
In Inspection entry pick tools/Options and set Auto Populate Data and it will load all of the inspections when the form opens.
There is also a drop down there, but I have never used it or the Auto Load search.
I dug a little deeper in help for the drop down. You can make a named search and have that execute when the form opens, so rather than all inspections maybe just PO receipts.
Well, I sure forgot to say that I was hoping to make this standard for any users of that screen. That may not be possible, but I mean, there’s only one dedicated QA part inspector, so I could just tell her to click that setting and that should be fine.
