Lot/roll tags
We are implementing E10.2.200. We ran into an issue with printing tags. We are using the job number as the lot. But, we need roll ID, also, So, the idea was to mix the lot and roll number together, i.e. lot 1234-001 roll, etc. However, when we print tags, we need the roll number portion to print sequentially, i,e, lot 1234-001, 1234-002, etc. Does anyone have a workaround?
Are you using BarTender for printing your labels?
No SSRS
and you just want it setup as 1234-001 for the label or as the lot number in the system as well?
I have little experience in the matter, but could he use a BAQ report?
