Hi all!
I’m trying to do a BPM in which the ‘PickList Comment’ and two custom fields (‘L’ & ‘H’) of the Parent (of the kit) go on the childs.
I did a custom code on the BPM in which i use 3 BAQs for:
- Recover all the info for the father (PartNum, Comment, L, H);
- With the FatherPartNum I get the childs;
- Finally I go in the order and for every child i copy Comment, L, H from the father.
And it should loop through the Fathers first and for every one of them loop between the childs and copy the info.
The problem is that I can’t seem to be able to loop every result of the BAQ. (none of those).
Ice.Contracts.DynamicQuerySvcContract boDynamicQuery = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.DynamicQuerySvcContract>(Db);
Ice.Tablesets.QueryExecutionTableset dsQueryExecution = new QueryExecutionTableset();
this.PublishInfoMessage(“OrderNum: " + OrderNum,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,”“,”");
ExecutionParameterRow drRow = new ExecutionParameterRow();
drRow.ParameterID = “OrderNum”; // name of parameter from BAQ
drRow.ParameterValue = OrderNum.ToString();
drRow.ValueType = “int”;
drRow.IsEmpty = false;
drRow.SysRowID = Guid.NewGuid();
drRow.RowMod = “A”;
dsQueryExecution.ExecutionParameter.Add(drRow);DataSet GetFields = boDynamicQuery.ExecuteByID(“GetFatherInfoForChilds”, dsQueryExecution);
try
{if (!String.IsNullOrEmpty(GetFields.Tables[0].Rows[0][0].ToString()))
for (int i = 0; i < GetFields.Tables[0].Rows.Count; i++)
PartNumFather = GetFields.Tables[0].Rows[i][1].ToString();
CommentFather = GetFields.Tables[0].Rows[i][3].ToString();
HFather = Convert.ToInt32(GetFields.Tables[0].Rows[i][5]);
LFather = Convert.ToInt32(GetFields.Tables[0].Rows[i][4]);this.PublishInfoMessage("PartNumFather: " + PartNumFather + "\nCommentFather: " + CommentFather + "\nHFather: " + HFather + "\nLFather: " + LFather + "\nRow Numbers: " + GetFields.Tables[0].Rows.Count,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"",""); Ice.Tablesets.QueryExecutionTableset dsQueryExecution1 = new QueryExecutionTableset(); ExecutionParameterRow drRow1 = new ExecutionParameterRow(); drRow1.ParameterID = "PartNum"; // name of parameter from BAQ drRow1.ParameterValue = PartNumFather; drRow1.ValueType = "nvarchar"; drRow1.IsEmpty = false; drRow1.SysRowID = Guid.NewGuid(); drRow1.RowMod = "A"; dsQueryExecution1.ExecutionParameter.Add(drRow1); DataSet GetFields1 = boDynamicQuery.ExecuteByID("GetChildKitLine", dsQueryExecution1); if (!String.IsNullOrEmpty(GetFields1.Tables[0].Rows[0][0].ToString())) { this.PublishInfoMessage("Rev: " + Convert.ToInt32(GetFields1.Tables[0].Rows[0][1]) + "\nPartNumChild: " + Convert.ToInt32(GetFields1.Tables[0].Rows[0][0]) + "\nRow Numbers: " + GetFields1.Tables[0].Rows.Count,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"",""); int Rev = 0; for (int j = 0; j < GetFields1.Tables[0].Rows.Count; j++) { if (j == 0) { Rev = Convert.ToInt32(GetFields1.Tables[0].Rows[j][1]); } PartNumChild = Convert.ToInt32(GetFields1.Tables[0].Rows[j][0]); RevNum = Convert.ToInt32(GetFields1.Tables[0].Rows[j][1]); if (RevNum == Rev) { this.PublishInfoMessage("Before last BAQ",Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"",""); var jobrow1 = (from k in Db.OrderDtl where k.Company == Session.CompanyID && k.PartNum == PartNumChild.ToString() && k.OrderNum == OrderNum select k).FirstOrDefault(); if(jobrow1 != null) { this.PublishInfoMessage("Comment: " + jobrow1.PickListComment + "\nLenght: " + jobrow1.Part_Lenght_c + "\nBase: " + jobrow1.Part_Base_c + "\nPart: " + jobrow1.PartNum,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"",""); jobrow1.PickListComment = CommentFather; jobrow1.Part_Lenght_c = LFather; jobrow1.Part_Base_c = HFather; } } } } }
catch
Can someone help me do the loop for the BAQs please?
