Looking for a reference
Because I like it when others post their solutions, here's the
solution for calling my vb.net label printing program from a custom
button on the Serial Number Assignment Form.
First I added a button called btnPrintLabels to the form then ran the
Event Wizard and added the Click event.
Private Sub btnPrintLabels_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnPrintLabels.Click
Dim edvJobSerialView as EpiDataView =
CType(oTrans.EpiDataViews("jobSerialView"), EpiDataView)
Dim edvSSNView as EpiDataView =
CType(oTrans.EpiDataViews("ssnView"), EpiDataView)
Dim strJob as String
Dim strSer as String
Dim blnVoided as Boolean
Dim ret as Integer
' Grab the JobNumber from the JobSerialView
strJob =
edvJobSerialView.dataView(edvJobSerialView.row)("JobNumber").ToString()
' Read each row in the ssnView and eliminate voided numbers
for each dr as DataRowView in edvSSNView.dataView
strSer = dr.Row("SerialNumber").ToString()
blnVoided = dr.Row("Voided")
if not blnVoided then
' Since the Shell commmand is hiding the program, indicate
which serial number is printing
oTrans.PushStatusText("Printing " & strSer, True)
ret = Shell("C:\Program Files\UFM\PrintLabels.exe " & strJob &
" " & strSer, 0, True, 5000)
oTrans.PopStatus()
end if
next
End Sub
Thanks for your help Bernie. Armed with this, I think I'll add a tab
to the Job Entry Form to display the currently assigned serial numbers.
Mark W.
...in V8 customization code.
I have a standalone program that prints serial number labels. I pass it the
job number. I thought, "Hey, wouldn't it be cool to call this program within
Vantage?" So I created a button on the Assign Serial Number form but I don't
know how to reference the Job Number (txtKeyField) on the form so I can pass
it to the program. Any thoughts?
Bonus question:
I'm currently opening up an ODBC connection, searching for the serial numbers
by job but if I knew how to reference the serial numbers on the same form, I
can do away with ODBC.
Thanks for any input.
Mark W.
Define a text box that will 'mirror' the form text box:
Private WithEvents txtJobNumber
In the form load event set your text box to 'mirror' the forms text
box:
txtJobNumber = CType(csm.GetNativeControlReference("46567b2e-6bc0-
4967-be35-a0ec6843838f"), EpiTextBox)
(you find the 46567b2e-6bc0-4967-be35-a0ec6843838f from the EpiGuiId
of the control you want to 'mirror')
Now you use txtJobNumber.Text property
HTH
Bernie.
pass it the
program within
but I don't
can pass
> Bonus question:
serial numbers
same form, I
> Mark W.
> box:
Interesting trick! I'll keep that one near-by.
I did have success with the EpiDataView route:
' Create a reference to the JobSerialView
Dim jwdv as EpiDataView = CType(oTrans.EpiDataViews("jobSerialView"),
EpiDataView)
' Create a string and assign the JobNumber for the current row
Dim strJob as String = jwdv.dataView(jwdv.row)("JobNumber").ToString()
This seemed to work. The reason I went this route is so I could try the bonus
question. I should be able to loop through the ssnView to get each serial
number on the screen but I haven't found any looping code yet...
Thanks Bernie!!!
Mark W.
Once all the S/Ns are in the data view:
Dim strSN As String
For Each dr As DataRowView in ssnview.dataView
strSN = dr.Row("SerialNumber").ToString()
Next
Of course you will have to define the references to the ssnview
dataview :)
text
> > box:
EpiGuiId
("jobSerialView"),
> EpiDataView)
the bonus
serial
> Thanks Bernie!!!
> Mark W.
