I started using .vbs scripts for my login, etc. scripts in my policies
and have had better luck with .vbs scripts than .bat scripts. Not sure
what you are using but these seem to be a little more useful/powerful
that .bat files. Let me know if I can help. There is also a lot of help
for these on Google. Gald you got it fixed.
Bob
Of Norm Watkins
Sent: Friday, May 09, 2008 3:41 PM
Subject: RE: [Vantage][OT] logon scripts to map drives
Problem solved: somewhere along the line, I shortcut the net use command
by
mistake or otherwise from "net use: \\server\share /persistent:no" to:
"net
use: \\server\drive no". It didn't affect mapping to the W2000 Server,
but
failed to map to the added "Vantage Server" without giving any errors.
Running the script as a batch file on my works station failed to map any
drive to either server, so that's when I found and corrected the
"/persistent:no" part. Go figure - isn't Windows wonderful?
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf
Of Jasper Recto
Sent: Friday, May 09, 2008 12:54 PM
To: 'vantage@yahoogroups.com <mailto:%27vantage%40yahoogroups.com> '
When you log in, you should see the batch file run.
What does it say when it tries to map your drive?
Behalf Of
Norm Watkins
Sent: Friday, May 09, 2008 3:48 PM
to answer 2 questions: the new server is listed in the "active
directory"
computers. and I can browse to the shared drives on the new server from
any
pc.
<mailto:vantage%40yahoogroups.com> [mailto:
<mailto:vantage%40yahoogroups.com>]On Behalf
Of Bob Sanders
Sent: Friday, May 09, 2008 12:05 PM
Is the Vantage Server in the domain ("active directory")?
<mailto:vantage%40yahoogroups.com>] On Behalf
Of Norm Watkins
Sent: Friday, May 09, 2008 12:41 PM
I've had already tried deleting all the mappings before I sent the email
to
the group, and the work station maps correctly to the "active directory"
server, but not to the "Vantage server".
Typing the "net use...." line from the batch file in a command window
maps
the drive successfully to the "vantage server.
[mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Behalf
Of Todd Hofert
Sent: Friday, May 09, 2008 9:15 AM
If you use:
@echo off
net use /persistent:no
net use v: \\entdb2\epicor
It will unmap/delete the mapping everytime the user logs off. You may
need the /delete to get rid of your current mappings, but I would opt
for /persistent:no for everyday use to avoid this in the future.
Todd
<mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Tony Hughes
Sent: Friday, May 09, 2008 11:10 AM
Subject: Re: [Vantage][OT] logon scripts to map drives
net use v: /delete
net use v: \\server\share
----- Original Message ----
kunal_vantage@... <mailto:kunal_vantage%40yahoo.com>
<mailto:kunal_vantage%40yahoo.com> >
Sent: Friday, May 9, 2008 10:04:23 AM
Try deleting all the mapped drives before you execute the NET USE for
the mapped shares. There is a TON of information available as reference
on the internet.
Kunal
To: "Vantage@Yahoogroup s. Com" <vantage@yahoogroups .com>
Sent: Friday, May 9, 2008 10:40:20 AM
Subject: [Vantage][OT] logon scripts to map drives
With the growth of the size of our Db, I'm adding a new server for
Vantage
(OS is 2003 Server). The domain controller remains the same (OS is 2000
Server, eventually upgrading to 2003 S). I've created logon scripts that
map network drives with the "net use" command in batch files for each
user
(assigned by user profile in Active Directory on the domain server).
However, the scripts run and map the drives to the domain server, but do
not
map the drives to the new server. I can map drives to the new server
through Windows explorer. I can ping the new server by name/IP address.
Any ideas why the script doesn't map to the shared drives on the new
server?
____________ _________ _________ _________ _________ _________ _
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/
;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
__________________________________________________________
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ<http://mobile
.yah
oo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>
.yah
oo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>>
have
and
vantage/files/.>
http://groups.yahoo.com/group/vantage/files/<http://groups.yahoo.com/gro
up/v
antage/files/>>
http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/g
roup
/vantage/messages>
http://groups.yahoo.com/group/vantage/linksYahoo<http://groups.yahoo.com
/gro
up/vantage/linksYahoo>! Groups Links
have
and
vantage/files/.>
roup
/vantage/messages>
/gro
have
and
With the growth of the size of our Db, I'm adding a new server for Vantage
map network drives with the "net use" command in batch files for each user
However, the scripts run and map the drives to the domain server, but do not
Any ideas why the script doesn't map to the shared drives on the new server?
Send me the logon script off line and I will take a look at it. Maybe
something will stand out.
Dale
Of Norm Watkins
Sent: Friday, May 09, 2008 10:40 AM
To: Vantage@Yahoogroups. Com
Vantage
user
not
server?
I have found if the mapped drive was created on workstation, net use
mapping in login script will not change an existing mapped drive.
Vantage
2000
scripts that
each user
but do not
server
address.
new server?
> thanks,
> Norm Watkins
> Engineering Mgr.
> ELECPAC
> 847-639-2307
Be sure to use PERSISTENT /NO in your script to avoid this. This will only map the drive for the session. This is equivalent of NOT checking the Reconnect At Login checkbox when manually mapping a drive at the workstation. Then if you change the path of a mapped drive in your script it will map properly on the next login.
If you mapped from the workstation and checked the Reconnect at login checkbox you will have to disconnect the mapping before the script will work.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Norm Watkins" <nwatkins@...> wrote:
Vantage
2000
scripts that
each user
but do not
server
address.
new server?
> thanks,
> Norm Watkins
> Engineering Mgr.
> ELECPAC
> 847-639-2307
Very - true that is why we always map drive via a logon script. That
way no matter what WS the user logs into they have their drives.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of bw2868bond
Sent: Friday, May 09, 2008 9:50 AM
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
Vantage
2000
scripts that
each user
but do not
server
address.
work.
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
behalf of bw2868bond
Sent: Fri 5/9/2008 10:49 AM
Vantage
2000
scripts that
each user
but do not
server
address.
work.
Vantage
2000
scripts that
each user
but do not
server
address.
Try deleting all the mapped drives before you execute the NET USE for the mapped shares. There is a TON of information available as reference on the internet.
Kunal
To: "Vantage@Yahoogroups. Com" <vantage@yahoogroups.com>
Kunal
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
@echo off
Todd
Of Tony Hughes
net use v: /delete
on the internet.
Kunal
Vantage
user
not
server?
<http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>
I've had already tried deleting all the mappings before I sent the email to
Typing the "net use...." line from the batch file in a command window maps
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Todd Hofert
If you use:
@echo off
Todd
Of Tony Hughes
net use v: /delete
on the internet.
Kunal
Vantage
user
not
server?
Check your permissions for the shares on the vantage server. Can you browse to them from any computer like so: \\myvantageserver\sharename
If that does not work then perhaps something larger is at work, for example, just to list a few
* maybe your vantage server does not have a DNS entry,
* the server might not be configured to do file sharing,
* if you have more than one AD server, then make sure all replication partners have the same logon script
This might sound a bit simplistic but I had a more or less the exact same problem a few years ago when I was upgrading an entire domain from NT to AD. The computers would not map to the new server no matter what I did, believe it or not, the solution turned out to be a simple reboot of all client computers in the domain. I am guessing it had something to do with each computer refreshing it's name lookup cache.
Kunal
Sent: Friday, May 9, 2008 12:40:32 PM
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com]On Behalf
Of Todd Hofert
To: vantage@yahoogroups .com
If you use:
@echo off
net use /persistent: no
for /persistent: no for everyday use to avoid this in the future.
Todd
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Tony Hughes
net use v: /delete
<mailto:kunal_ vantage%40yahoo. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
on the internet.
Kunal
To: "Vantage@Yahoogroup s. Com" <vantage@yahoogroup s .com>
Vantage
user
not
server?
<http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ>
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Of Norm Watkins
to
maps
Behalf
Of Todd Hofert
If you use:
@echo off
Todd
Behalf
Of Tony Hughes
net use v: /delete
on the internet.
Kunal
Vantage
user
not
server?
have
and
to answer 2 questions: the new server is listed in the "active directory"
computers. and I can browse to the shared drives on the new server from any
pc.
Of Bob Sanders
Of Norm Watkins
to
maps
Behalf
Of Todd Hofert
If you use:
@echo off
Todd
Behalf
Of Tony Hughes
net use v: /delete
on the internet.
Kunal
Vantage
user
not
server?
have
and
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Norm Watkins
pc.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>]On Behalf
Of Bob Sanders
Of Norm Watkins
to
maps
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]On
Behalf
Of Todd Hofert
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
If you use:
@echo off
Todd
[mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Tony Hughes
net use v: /delete
From: Kunal Ganguly < kunal_vantage@...<mailto:kunal_vantage%40yahoo.com>
on the internet.
Kunal
Vantage
user
not
server?
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ<http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>
< http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ<http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>>
have
and
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/files/<http://groups.yahoo.com/group/vantage/files/>>
http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages>
http://groups.yahoo.com/group/vantage/linksYahoo<http://groups.yahoo.com/group/vantage/linksYahoo>! Groups Links
Problem solved: somewhere along the line, I shortcut the net use command by
mistake or otherwise from "net use: \\server\share /persistent:no" to: "net
use: \\server\drive no". It didn't affect mapping to the W2000 Server, but
Of Jasper Recto
To: 'vantage@yahoogroups.com'
Norm Watkins
pc.
Of Bob Sanders
Of Norm Watkins
to
maps
Behalf
Of Todd Hofert
If you use:
@echo off
Todd
Behalf
Of Tony Hughes
net use v: /delete
on the internet.
Kunal
Vantage
user
not
server?
have
and
vantage/files/.>
antage/files/>>
/vantage/messages>
vantage/files/.>
/vantage/messages>
